2023 R4 LV Tools
Honda4lifeKS
Honda4lifeKS
15
104
Kansas
  1. Talon R LV
Just curious as to the recommended tools specific to the Talon that I should have on the machine. Socket sizes, torx, Allen etc. Thanks!
Reactions: TxDoc and NTCPrezJB
5,061
22,707
Welcome from the once great state of Colorado. We'll need pics, it's da rulz. :cool:
I haven't seen a Talon specific tool thread but I just carry the same basic tools I've used on every Japanese motorcycle that I've owned for the last 5 decades. You'll probably want a spanner that you can use to adjust your spring preload (for adjusting your ground clearance as the springs take a set). There's a link in the NTO thread for my 2 R - not sure if the LV uses the same diameter preload collars or not.
If you follow along on the site, you'll pick up what you'll need by the time that new Talon needs to meet up with any tools.
There's a lot of good info in these two threads -
Vikes79
Vikes79
SKOL!
11,017
106,999
South Dakota
  2. Talon X4 LV
Welcome to the site!
What @CID is saying is legit. You will find more general trail ride tool / parts recommendations.
Be careful….some advocate for bringing the entire garage of tools…others are okay with a roll of duct tape, few beer cans, and 3 zip ties.
Honda4lifeKS
Honda4lifeKS
15
104
Kansas
  1. Talon R LV
Thanks!!
Scoop
Scoop
4,250
15,923
  3. Talon R LV
Yes, it's ChinaZon, but $35 gets the entire set and case. I've tested a couple real good.
SUNKPMCKP 1/2" Drive Deep 6-Point Impact Socket Set, 9-Piece METRIC Spindle Axle Nut Impact Socket Set, Cr-Mo, 29mm - 38mm
Screenshot 20240216 183948 Amazon Shopping
Reactions: Honda4lifeKS
