P700 External snorkel
slikoriko
slikoriko
68
348
Prescott Valley AZ
Drilled a 2 inch bulkhead fitting in stock air box for additional two inch snorkel. One snorkel alone was restricting the flow . Using shop vac 2 inch vacuum hoses for bends. Still need to clean up clamps. With tire pressure at 25 psi. GPS reads 42 mph.
20230610 152504
osobad
osobad
6,786
59,766
Tampa Bay Florida
I have a question for you. How did you determine air flow was restricted? 2 inch vac hose should flow as much as or close to 2 inch pvc. I have done the same but ran the hose all the way to the underside of the roof. My findings are it has more air flow than the stock set up. Mine was running. leaner is how this was determined
Glock21user
Glock21user
1,825
9,092
Livingston county, Mi.
X2. Look at the pics of mine and I have zero issues.
Leaner would indicate too much air, not enough fuel. That would mean your snorkel was flowing more than enough air.
slikoriko
slikoriko
68
348
Prescott Valley AZ
Placing my hand over the inlet ,has some suction. With another two inch. Now has less suction and acceleration is much noticeable. Without vacuum gauges i will never know. The actual difference
