P1000m5 My C-Fab Journey and Review
JenElio
JenElio
65,181
609,911
Loxahatchee, florida
I will most likely not get 3" spacers for the rear. But it may bug me since I will know the front is slightly wider than the rear after the addition of 2" spacers to the front :p With the current front 1" spacers at full turn the tire hits the lower shock mount.
Really? Ok excuse me if you've talked about it already I haven't really read through your build that much. Is it rubbing cause of the wheel offset/tire size you have or is it a camber issue?
208,028
/ Toe in issue?
Reactions: JenElio
JenElio
JenElio
65,181
609,911
/ Toe in issue?
🤷‍♂️?.... something ain't right, if it's not the wheel offset causing the issue then I would think camber over toe. Bad toe I think would rub the a-arms before the shock mount, where camber might when turned........🤷‍♂️ I'm no expert though, I've been wrong before 😂😂
Robobrainiac
Robobrainiac
2,470
8,621
The original rubbing was on the fox shock reservoir. During compression the reservoir would hit the top of the tire in any turning radius. The reason the fox shock was so close to the tire to begin with is from the bracket lift kit that moves the shocks outwards to "stand them up" to obtain lift. With the c-fab arms the tire hits the bottom of the shock mount while at about 90%+ of full turn. Larger front spacers or more negative wheel offset would fix both problems.
208,028
Yep something is a miss?
JenElio
JenElio
65,181
609,911
Gotcha, I just realized the arms have a built-in lift.....guessing it pushes the shock mount tab closer/higher then the stock location causing the rub eh? I guess most times they couple that set up with portals which would act as your wheel spacer 🤔
If your 2" spacers work then 👍.....I personally wouldn't go 3” at the rear though. That seems like a lot of strain on the hubs/suspension........just my 2 cents.
Hope you get'r figured out 👍
Robobrainiac
Robobrainiac
2,470
8,621
You are correct about shock mount placement/C-Fab height for the mount tabs. I don't want to go that wide with the spacers. I am sad the width won't be the same front to rear now. Most people probably won't be able to tell without a tape measure. The best solution would really be new wheels with proper offset.
Robobrainiac
Robobrainiac
2,470
8,621
I did a little research this morning and I might be able to clear with 1.5" spacers on the front. So I ordered a set of those as well. I have 1.5" spacers and 2" spacers in the mail now. Hopefully they will be here before the takeover.
Robobrainiac
Robobrainiac
2,470
8,621
I got an early lunch so I will start on the machine again
20230518 114047
Robobrainiac
Robobrainiac
2,470
8,621
Extended shock length
Front 19 3\8"
Rear 19 1/2"
Sitting on the ground front and rear measure 18".
Robobrainiac
Robobrainiac
2,470
8,621
So now I am at a mental crossroad. The rear at the hitch measures 16.5". So I lost some height in the rear. However, I have around 1.5" of shock compression from fully extended to static/parked shock length. I test drove thru some holes and bumps and on and off curbs in the parking lot of my workplace. I know it's not an offroad park but I can already tell it is a much smoother ride. For how it feels and the shock length I don't think I want to add more pre load. My current ground clearance from the SuperATV skid is 14.75" in front and 15.25" in the rear measured from the side between the wheels at the furthest edge of the skid. Should I leave it, add pre load, or remove some pre load?
Reactions: JenElio
208,028
Check your spring sag that's the only way to tell. I've talked about it many times here. Here's the last time I will talk about it. Jack your S X S up until your shock shaft quits extending, take measurements front and rear. Put simulated load in your S X S including passengers, roll it back and forth to let it settle, measure again. Compare measurements. Usually 1.25 to 1.5 works for spring sag fully loaded works.
Robobrainiac
Robobrainiac
2,470
8,621
I currently have 1.5" with no driver or passengers
Robobrainiac
Robobrainiac
2,470
8,621
That was the worst alignment I have ever done. I spent 3 hours on it trying to get it as perfect as I could. I am happy with the front. The rear does not cooperate as well as you would hope. Visually it all looks good. I think I will eventually get an old school alignment kit. Something I can do at home. Every control arm adjustment requires you to basically remove it to adjust the heim joints. The left rear toe basically hit a wall and no matter how hard I tried the toe just maxed out to where it was at and it would only move the camber. I used an engine hoist to maneuver around the rear arms. Time will tell how it will treat the tires.
20230518 193038 20230518 180215 20230518 194529
Reactions: JenElio
Robobrainiac
Robobrainiac
2,470
8,621
Now that the alignment is finished I can see where any rubbing problems would be. The tires just barely clear the lower shock mounts on the front. At full turn the tires rub the inside of the lower control arms.
20230518 200440 20230518 200424
Reactions: JenElio
JenElio
JenElio
65,181
609,911
Reactions: Robobrainiac
Robobrainiac
Robobrainiac
2,470
8,621
Do you have steering stops installed?
I do not. I thought about getting some. I appreciate how tightly the pioneer turns and I am not sure how much radius I would lose.
Reactions: JenElio
JenElio
JenElio
65,181
609,911
You lose a bit of turning radius, and it sucks.....but, it'll eliminate the rubbing on your a-arms 🤷‍♂️.
Supposedly if you're running the forward arms during 4lock at full turn/compressed your axle "could" pop out of place. Doesn't apply to the Rhino 2.0 IIRC 🤔
Robobrainiac
Robobrainiac
2,470
8,621
I made some adjustments yesterday on the rear shock preload. I am assuming the rear shocks settled in a bit. I noticed after we added our gear for ride royal blue the rear sagged very heavily. I put 22 old car rotors into the bed to replicate weight. I think it should have been around 300lbs or more. I was a little less than 16" eye to eye on the rear shocks and a little less than 39" to the ground from the bottom of the N on the tailgate. I cranked on the rear shock preload adjustment, then drove a few circles, and measured. I used the socket method to make it easy to keep the preload even on both sides. I am up to a 29mm impact socket that measures 1.65". It took me about 4 tries to get it right. When I was done I was at 17" eye to eye on the rear shock, and a little over 41" to the ground from the N on the tailgate. I unloaded everything, did some more circles, checked the measurement one last time and the rear shocks are 18" eye to eye, the N on the tailgate measures 44" to the ground. I did the alignment again and now I need some testing.
20230622 074411 20230622 121703 20230622 121712
Reactions: JenElio
