P1000 Need help with electrical failure (power steering went out, then check engine, then engine totally stopped)
thirdparty
68
96
USA
Just happend this afternoon after about 2 hours of stop and start riding doing chores. I stepped out to close a gate, got back in and the engine died. I had a NOCO jump start near, started fine, but no power steering. Ran for another 15 minutes, then same thing. Jumped it two more times, but it only runs for about 10 minutes then dies.
I took the battery completely out charged it fully on a 10A charger to fully charged. Checked all contacts, wire brushed everything--all tight. Put it back in, but all of the dash warning lights came on and it wouldn't start by itself. Jumped it again on the trailer and now it's sitting in my driveway.
What next? I did find a thread for checking engine ground points here. (See post #10): Ground thread with diagram
Here are two video showing what it does:
First video is first known failure:
Second video is after I fully charged the battery, wirebrushed all contacts, etc.:
I guess I really need some help finding all potential ground contacts so I can check them. Anyone have a good thread or diagrams?
Thanks in advance!
208,029
Thanks in advance!
Take the battery to a auto parts store and have it tested,
Mark in Northern Iowa
466
2,082
Floyd County, Iowa
kramnella.wixsite.com
grounds
Electrical issue1
But like others said above.
Sounds like a bad/weak battery
Load test the battery.
Have a good day
thirdparty
68
96
USA
grounds
Have a good day
So the initial reading on the battery was 10.4 V, which is bad. I put it on the tester (handheld automotive type with the heating element) and it read weak and zero with load. I measured the V again and it was 12.3 V. WTH?
I put it on the tester again and it read in the green, but zero with load. So, I guess it's D-E-A-D.
What's the best access for those grounds? From skidplate? Under the bed? I already checked under the seat, and not much is accessible there.
Reactions: Buggyman
thirdparty
68
96
USA
Yes, the battery is toast. If you put it on a charger, the voltage may read good . . . that's called a "surface charge". Even so, the battery has no real capacity.
yep. I charged and installed a new battery. no problems anymore. But, I want to check the grounds anyway.
What's the best access? Through the rear seat floorboards?
I'm suspicious becuase this is a newish battery and I installed the permanent NOCO leads so I can just plug in the trickle charger when I'm away. None of that mattered to keeping the battery charged and it totally failed.
Thanks
Mopower58
Mopower58
CST is the Best!
71,228
652,081
Crystal Springs,Ms.
Glad you found the problem. My original battery lasted 6 years and never had a trickle charger on it. Make sure you buy a quality battery. I installed a lithium battery in mine last year but I just installed a winch and going with a dual battery setup. I have heard good reports on the Mighty Max battery.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
The fact you tried to treat the battery well, has nothing to do with it. It was likely damaged before you got your hands on it.
I wrote about this before. With Honda's supply chain issues, and painfully slow deliveries, I suspect their batteries are sitting on the shelf for far too long. Lead acid batteries, at normal temperatures, self discharge about 5% a month. To keep them healthy, and prevent plate sulfation, they need to be charged every 6 months in storage. I strongly suspect that Honda didn't do that. My '21 P1K-5 SE battery bit the dust at just over 1 year.
Rayger143
Rayger143
2,757
23,895
Winfield, BC Canada
100% agree. A "fresh" battery is always best.
