P700m4 New to the Thread lots of questions long post.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I haven't paid to much attention to a arm upgrades and such, but I believe @Gator was contemplating or has them. If I am wrong Gator, I apologize.
swsebek
swsebek
2,854
5,829
pa
My 28s made a huge difference in ride too.With Fox shocks you may not need a-arms
Reactions: CumminsPusher
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
The superatv arms are a direct bolt on item, no need for upgraded axles or anything like that. They give 2" of ground clearance but that is it, no stretched out wheelbase with these arms unfortunately.
Fox shocks are great, I've been running them for awhile now and have no complaints. Out of the box they give you about an inch and a half lift, but you can adjust the ride height, up or down. And might I also suggest disconnecting the sway bar. Don't expect the pioneer to ride like a rzr even with the foxes, like @CumminsPusher said. But they will definitely bring it to the next level.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Oh and for the 28"s, some fit without a lift, some don't. I think if you are running the foxes or commander shocks you'll be ok without a lift, because they both have a bit of lift built in.
Reactions: swsebek
FlHondaSxS
FlHondaSxS
51
65
South Florida
What is the benefit of disconnecting the sway bar? Thanks for the info on the A-Arms. I have no delusions of the pioneer ever riding like the rzr lol I just want to be able to ride and not feel like a shaken baby by the end of a ride.
FlHondaSxS
FlHondaSxS
51
65
South Florida
Alright, I'll have to do some hunting down on tires to figure out what I want to find out if there is no rub.
swsebek
swsebek
2,854
5,829
pa
do 28s fit on stock? I thought you'd need to modify it some.
I run maxxis big horns and they don't rub stock,,,,,BUT they do rub my mud buster bolts and it's not bad but sounds horrible.My sway bar is still connected because my wife and daughter drive.If you take it off it will allow you to articulate better and keep all tires planted,,But if you slide too hard or break to hard on a corner or uneven surface you could flip easy.If you want -just unhook it and tape it up and try it.but be careful while chasing them 1000s or pounding beers
FlHondaSxS
FlHondaSxS
51
65
South Florida
I gotcha, I'll be on mud mostly so I'll be looking at some mud tires pref 28x10-12
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
28" tires - I have 28" swamp lite's and they have never rubbed.
Shocks - New shocks are a must have. Fox's are an excellent choice and you will feel it immediately.
Sway Bar - I've said this before. They sway bar is on there for stability. Honda deems it necessary for SAFETY. I took mine off and will not put it back on.
A-Arms - I like the arched arms. It's hard to quantify how much they help. Mine are definitely beefier than the stock and that gives me some degree of confidence. I don't have the super atv arms. Mine were made by a guy in Louisiana. I could have asked for more lift but I was afraid to go too high.
Portals are available but they are $3000.
320,749
I agree on sway bar removal but like how Gator put it best. I'd suggest pulling it and seeing for yourself. It's easy enough to reinstall Be a little cautious on high speed maneuvers and side hills a little.
Vato
Vato
180
159
Leave the sway bar alone. Honda installed them for a good reason.
I installed the CanAm shocks and like them a lot.?better ride! At last year's event at Ride the Blue spiffy and myself traded rigs during a night ride. I had to drive his turbo charged 700.....that was a hoot and another story. He said that he liked the CanAm shock ride better than his fox shocks.
