P500 P500 Valve adjustment
solrus
solrus
1,629
2,511
Montana
Charged 84$ . Intake valve was a bit off.
Sent from my XT1585 using Tapatalk
34,174
hobbytrucker
hobbytrucker
digby ns
My intake was out quite a bit the exhaust was ok
Reactions: Lburou
RDRC
RDRC
40
70
Colorado
Just checked the P500 valves for the first time(1400 miles). Intake was slightly loose, probably could have let it alone but after going thru the trouble to get at them, I tweaked it. Exhaust was right on. I wasn't having any noise or starting problems, just thought I would check them. I don't plan to check them again unless a problem crops up. Definitely a PITA.
Reactions: Lburou
34,174
Definitely agree with the last line!!
doolin64
doolin64
187
278
Completely agree that checking valves is a PITA! I just fired my bike up and oh boy. We have valve racket. I may bring it to the dealer. I just want to be done.
34,174
What'd you do doolin, make it worse??
doolin64
doolin64
187
278
Yes! Going to give it another try tomorrow night. I think we may have slightly off from TDC. It looked like we were there. We could see the T and _ but it must have been off a hair.
34,174
Yeah, see that's the reason I've never attempted it. If it starts good, runs good and isn't making noise, I'll not do anything with mine. I don't even have confidence with the dealership. When I asked them a year ago, they hadn't even adjusted the valves on a P5.
doolin64
doolin64
187
278
I'm hoping they've at least adjusted them on a Foreman...or whichever Honda atv has this motor.
I thought mine seemed to chug a bit too much to turn over. Yesterday when I went to fire this up for the first time since the adjustment, it turned over real fast. Success! Till I heard the clickety clack. I believe my valves were really tight and now I made them too loose. [HASHTAG]#shouldhaveleftitalone[/HASHTAG]
Reactions: Lburou
34,174
That's what it sounds like. Just be sure you start that dude at the dealership before you pay for the service and drive off!
doolin64
doolin64
187
278
Where abouts on motor is the spot where you can spin the crank instead of using the tire method. These darn Honda motors confound me.
34,174
Hell if I know, I've not attempted it. We quit having to adjust valves on cars 40-50 years ago. This and the stupid oil filter arrangement is my two chief gripes about the P5. I'm surprised we don't have points and condensers to contend with as well.
Razorback
Razorback
397
999
Van Buren, AR
Which port is intake or exhaust? Didn't see it mentioned anywhere.
41,798
Haven't done this yet...but here is a pic of the access plate to rotate the crank. Didn't see a pic of it in the thread...
Crank hole cover
Saw it on the back of the engine and said Hmmmm...
Confirmed with a 2014-2016 Foreman 500 FSM that this is what its for. Looks like tight access on a 500, but i ain't skeerd...
Prob a 17mm in there on the crank.
I am thinking it looks easy to remove the rear fenders/rack (looks like maybe 8 bolts/2 clips) to get straighter view of the timing hole while also tilting the batt box away?
I've already been down to the valve caps to investigate a coolant leak. Typica Honda with 8,000,000,000,000 plastic rivets taking most of the time.
This may stun everyone, but i got no owners manual with my machine. Where can i find one...maybe in PDF?
Also, I've found a paper version of the service manual, but I'm thinking that after decades and prob 10 thick, expensive books, i may just go digital on this one. Anyone know where i can get a PDF FSM?
One caution on the adjuster locknuts:
The manual states something like 13 foot pounds as @Code54 said (approx 156 inch pounds). My experience with these has shown that repeated torquing of these to the FSM level will strip them. Most of you seem determined to NOT adjust your valves, so this won't be an issue. But for those who do, be aware...
...Other manuals for different machines I've owned have the torque listed from 144-150 inch pounds, but even at the minimum, they eventually stripped. I ultimately settled at 130 inch pounds and had no further issues.
41,798
Did mine today. Both were loose, esp the exhaust.
Yes, this is a bit of a pain. I think its just a consequence of using an engine that was never meant for SxS duty. That silly battery box is a big part. After taking some wire clips loose, i was able to move it completely out of the view of the timing hole. Yes, the captured "nut" on the battery box spun and had to be wedged to break loose (SURPRISE!).
I also used the cover i mentioned above to rotate the engine (clockwise, viewed from the rear). It's a 17mm. The valve access caps are 24mm.
Someone mentioned that they thought the airbox would need to be removed. I don't know if this is necessary, but the improved access is worth the small amount of work needed IMO ( I already pulled the rear rack/fenders for the job).
Again...that battery box is simply in the WRONG place. Tight in there too; Gonna be a pain when i add the winch (somebody had installed a trickle charger plug).
All in all, nothing too earth shattering...just a lot of rivets as usual.
BuckCreek01
BuckCreek01
279
488
Griffin Ga.
I'm not comfortable doing a valve adjustment on a new machine or in general. This puts me in a tough spot because I do not trust the dealer to do it correctly. What do you all think I should do? Take it to the dealer or just run it without adjustment?
34,174
It doesn’t need to be adjusted unless you hear them, or it’s slow starting. I’ve got 3,000 miles on mine without having adjusted. People have 20 year old Honda ATV’s all over that have never been adjusted.
