P500 Pioneer 500, What Tire Pressure do you run?
What Tire Pressure do you run on your Pioneer 500? Pick 2 - Front & Rear
  • Front 0-4
    Votes: 11 5.0%
  • Front 5-6
    Votes: 38 17.3%
  • Front 7-8
    Votes: 61 27.7%
  • Front 9-10
    Votes: 104 47.3%
  • Front 11 +
    Votes: 5 2.3%
  • Rear 0-4
    Votes: 8 3.6%
  • Rear 5-6
    Votes: 35 15.9%
  • Rear 7-8
    Votes: 56 25.5%
  • Rear 9-10
    Votes: 92 41.8%
  • Rear 11+
    Votes: 7 3.2%
  • Total voters
    220
63,410
Reactions: 100Acre
Crookedcreek
66
22
I stuck with the Honda recommended 10 PSI (as I voted above) for no other reason than I don't know any better! I will be interested and watching the vote results to see what others may find works better, and why, and under what circumstances/riding and use conditions.
Reactions: rtn001
hoggr9
88
Xenia, IL
I found that about 6 lbs front and rear seems to work well for general riding at a modest pace. If I were loaded or planning on pushing the pace I would go up from there. But that seemed to help smooth out the bumps.
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
I used to run 4 psi on my 8 ply roctanes but it felt like I was riding around with the parking brake on so I pumped it up to 8 psi. At 4 psi the 26s shrink down to about to the stock size of 24 so that was another reason to pump them back up. I put 12 in them today,felt like I gained 30% more power.
Reactions: rtn001 and AlR
sharphook
5
more air more flats purchase more tires who makes the $$$$$$$$$$$ 5 is a safe #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reactions: rtn001 and SSinc
SBuckJ
SBuckJ
214
216
Central PA
I ran 10psi when I originally purchased the machine but in the snow, in 4wd, it seemed to hop the machine BAD. I went down to 6PSI and it helped dramatically. Kept at 6 in the snow for the bigger footprint. Summer I may go up just a bit
Reactions: rtn001
I
iluvuk
22
5
I tried 7psi on my bighorns but it was mushy. I moved up to 10psi, better handling on dirt roads and rocky trails. I think on sand I would go back down to 7psi for traction.
Reactions: rtn001
G
Geoff
26
26
Falling Rock,W.V.
Pioneer 500 owners,
What tire pressure do you run?
FYI - Honda recommends 10 psi cold.
Please answer in the poll or talk about it below.
Thanks.
In psi, vote twice Front & Rear, you may change your vote.
this is for stock tires...what about 26" radials?, front being 26x9x12, rear being 26x11x12.....thanks
Reactions: rtn001
265,332
From my prior experience with STI Roctane XD's being 8 ply radials 8 PSI seems to be about right combo for ride, traction, and ensuring you don't pop it off the bead with nasty rock & ruts.
Moose308
386
289
Pioneer 500 owners,
Thanks.
25 inch bighorns factory rims 9 psi
Reactions: rtn001 and Ian
Moose308
386
289
I also run 25" Bighorn Tires. They were set at 10 PSI all round when I took delivery of my Pioneer 500, however I have now found 6 PSI is the ideal pressure for both front and rear. I can stay in 2WD and go most places around the farm.
Thanks
Reactions: rtn001
ncred02
ncred02
1,031
1,769
Raleigh NC
I had mine mounted Saturday and never checked until just a few minutes ago. I took it for a spin around the neighborhood and it felt like i was riding on rocks. The folks at the tire shop had them all over the place, even 30 in one tire. !5 in another and 25 in the other two..
I dropped them to 10 all around and when I ride tomorrow Ill adjust as needed
265,332
Running 8 PSI in 26 x 9 X 12 Roctane XD mounted on factory rims.
CBC89
CBC89
66
73
I have 26x9.5 vampires on stock wheels running 5 PSI in all tires. Mainly because on these tires it says maximum operating pressure is 5 PSI. Don't want to go any higher than recommended. Doesn't seem to ride bad and they pull like a mule.
Reactions: rtn001
p500fan
p500fan
418
358
Sand Point, AK
My Ripsaws came to me mounted on 14" aluminum rims. They were already @ 10psi, and I have never seen the need to modify that. Just bolted them on, and went riding. If it ain't broke, let 'er bump! Ha!
Reactions: rtn001
miano248
miano248
370
398
oceanside long island new york
my p500 on 30x8x12 itp rims 4psi works great
Iphone pics 012
