P500 Pioneer 500, What Tire Pressure do you run?
What Tire Pressure do you run on your Pioneer 500? Pick 2 - Front & Rear
  • Front 0-4
    Votes: 11 5.0%
  • Front 5-6
    Votes: 38 17.3%
  • Front 7-8
    Votes: 61 27.7%
  • Front 9-10
    Votes: 104 47.3%
  • Front 11 +
    Votes: 5 2.3%
  • Rear 0-4
    Votes: 8 3.6%
  • Rear 5-6
    Votes: 35 15.9%
  • Rear 7-8
    Votes: 56 25.5%
  • Rear 9-10
    Votes: 92 41.8%
  • Rear 11+
    Votes: 7 3.2%
  • Total voters
    220
41,674
7 to 8 in 26" BH 2.0's.No rocks here,some stumps.Lower pressures seem to sap power away more than I care for.
I dont know how the 2.0's are, but my original BH's i had on the 700...I could run 2-3psi more pressure and get the same ride quality. Best riding tire I've ever run. They are pricey for a reason, I guess.
Reactions: crewcabrob
nctrailboss
nctrailboss
440
1,454
north carolina
I do t know how the 2.0's are, but my original BH's i had on the 700...I could run 2-3psi more pressure and get the same ride quality. Best riding tire I've ever run. They are pricey for a reason, I guess.
I feel the small abrupt stuff more as I get close to 9psi.As you said,they are really good tires.I had a set of the originals in 2004 on an atv.I had trouble with them losing air and breaking the bead seal on delta steel wheels.I think they had just been released on the market then.
41,674
I'm thinking they 1st came out as a bias ply and the radial came later. But...as I'm getting older, I've found the old melon less reliable.
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
5 psi in all four corners 27x9-12 front and 27x11-12 rear sunf big horn knock offs
Wisdumb
Wisdumb
50
138
Independence, KY
Running 4psi all around on Sedona Mud Rebel RTs. They are seriously tough tires at 8 ply so even at 4psi they have almost no deformation under load. Running ITP SD bead locks as well.
Mudder
Mudder
NTC Ambassador of Walls
11,304
83,932
I put some 27s off a Pioneer 1000 on my P500. I have 10 PSI all around and was wondering if dropping it down to 8 PSI would help smooth out the ride without causing problems. The ride over washboard trails is pretty hash.
8 psi with 27 x 11 (r) and 9 (f) on 14 inch rims with non-radials is what I run on my P500. I have done 6 psi on a rocky trail, slo-poke speed. Hope this helps.
kosh
kosh
42
104
Ste. Anne, Manitoba
My tires are on 12" rims. Did you find that the lower pressure smooths out the ride? By the way, I meant to type "harsh" not "hash in my original post.
41,674
I think all of us who knew and interacted with him were shocked and sorry for his sudden death.
Here is the announcement if you'd care to know...
I ran 26's on my 500, as have many others. No clearance issues at all.
Ranger454
SC
Not a P500, but I just bought my mom a P520 and am concerned about the lack of power steering when going slow.
currently running the factory tire pressure in the factory tires/wheels - does anyone have input on how much increasing the pressure 5psi would make on slow-speed steering?
since air is cheap, trying this method before throwing down for a power steering kit. :cool:
Red500
Red500
5,184
56,261
Greeneville, Tn.
It might make it ride a little rougher but other than that I don't think it'll be a problem.
