P500 Pioneer 500, What Tire Pressure do you run?
What Tire Pressure do you run on your Pioneer 500? Pick 2 - Front & Rear
  • Front 0-4
    Votes: 11 5.0%
  • Front 5-6
    Votes: 38 17.3%
  • Front 7-8
    Votes: 61 27.7%
  • Front 9-10
    Votes: 104 47.3%
  • Front 11 +
    Votes: 5 2.3%
  • Rear 0-4
    Votes: 8 3.6%
  • Rear 5-6
    Votes: 35 15.9%
  • Rear 7-8
    Votes: 56 25.5%
  • Rear 9-10
    Votes: 92 41.8%
  • Rear 11+
    Votes: 7 3.2%
  • Total voters
    220
Arizona
Arizona
102
201
Casa Grande & Show Low Arizona
I'm running 26" Duro Frontier Radials, I run 5 PSI as it helps soften the stiff suspension a little. I've found bias ply like the factory tires need more PSI, and radials tend to need less, they often look half flat, but it's because radials have a softer sidewall, bias have stiffer sidewalls.
Reactions: rtn001 and 70Bones
rocmar
rocmar
4,741
5,773
4 CORNERS
True...
but it's also true..
with 5psi...your tire height
is less...so 26"...is 24. 3/4"
WillyBill
WillyBill
Wheeling Addict
472
1,878
Clinton, Utah
  1. Talon X LV
Running 25" Bighorn 2.0 stock width on stock rims - 4 lbs front and 5 lbs rear - one or two riders - REALLY rides nice compared to the recommended pressure and bigger contact patch makes big difference on where it will go - for heavy loading would go up 2-4 lbs per tire.
Sgt_Russ
Sgt_Russ
Sparks, NV
Checked mine the other day one seemed low so I put 10 all the way around and it seemed a bit rough on rocks. Thinking of 6-8 to be honest. Less bounce helps us with junk backs.
I'm running 2 in my Sedona's, they are a 6 ply tho. Might go to 3 front and maybe 4 rear when loaded. Max is 7 psi on those at 500 lbs. Stock size with that 10 psi recommendation is just too much. Max 8 in those for me.
Reactions: rtn001
Sgt_Russ
Sgt_Russ
Sparks, NV
14" ITPSS312 wheels with 26x9 front and 26x11 rear rip-saw RT's (Sedona) 4 psi front, 5 psi rear. Very stiff tires, and I really think they were engineered for a heavier machine- max load inflation is 18psi for near 800lbs load capacity per tire. I don't load heavy, and 4-5psi gets most of the tread on the ground. Tires were shipped with 12psi, and it was like riding on solid tires- real bad. About 600 miles so far at my pressure setting. They handle and track very well, and are showing no appreciable wear at this point. Traction over stock tires was immediately apparent, and improved noticeably with lower pressure.
I run the same ones on rougher terrain, 2 psi all the way around, haven't popped a bead yet.
Reactions: rtn001 and JWB
Gem99Ultra
Gem99Ultra
84
95
Warm Springs, GA
I just switched to SunF 26's radials all the way around. Checked tread contact with the chalk method. Started out at 10psi and dropped 1/2 pound 3 times until I got a good wear pattern at 8.5psi. It could stand to drop to 8psi without consequences. Rides and drives 100% better.
What I did discover is that the rear axles apparently are spooled, i.e. locked, resulting in a locked rear end full time. Perhaps that's good for most people, but that's the cheap way to go - IMHO only. Something more of a posi-track type differential, allowing the inside tire on turns to not be forced to scrub all the way through turns. That will also result in some broken rear axles when making tight turns on hard surface.
Going the 'posi-traction' or 'sure grip' way would be a little more costly, and would certainly be the preferred way. That info, of course, is never shared with prospective buyers. But at a small higher cost.
Reactions: rtn001
SouthwestORV
SouthwestORV
744
1,730
Taylor, Arizona
I prefer a softer ride, so still running stock tires and running about 9 psi all around.
Reactions: rtn001
solrus
solrus
1,629
2,511
Montana
BH 2.0 26", run 5 psi, if drive in town go to 7 psi, if chains then 10 psi.
Sent from my Moto Z (2) using Tapatalk
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,759
183,031
Grand Junction, CO
My Ripsaws came to me mounted on 14" aluminum rims. They were already @ 10psi, and I have never seen the need to modify that. Just bolted them on, and went riding. If it ain't broke, let 'er bump! Ha!
Same here with my Ripsaws, 10psi for all riding and have never changed the pressure up down in almost 4 years.
Shive
I'm switching to Duro frontiers for the same reason. Most of my riding is hard surface. What size tires did you get and did you have to install spacers?
Reactions: rtn001 and solrus
Ian
Ian
7
11
Australia
I run Bighorn 26" on standard rims. No spacers. I live in undulating country and normally run 6 psi in winter and for most of the year, however if i occasionally venture on bush tracks i might increase the pressure to 8 psi. Most of my farm work is in 2nd and 3rd gear.
Idahocrawler
Idahocrawler
47
72
1674DD12 EF05 443D 8B2F 47E720696B34
Have you tried running them at 7 per the manufacture? Just curious if it made for a better rider
Reactions: rtn001
SouthwestORV
SouthwestORV
744
1,730
Taylor, Arizona
I'm down to 7.5 psi now on my SunF Power II's. I have found that this pressure works great for me all-around.
Reactions: Idahocrawler
Ian
Ian
7
11
Australia
No snow in Australia at the monent. I run 26" Big Horn Tyres on standard rims. 6 psi is the ideal pressure for pulling a Flail Mower and "pottering" around the farm. I would suggest 4"to 6"psi would be a good starting point. You need a bit of grip if your working in wet snow and you wont be travelling fast. Hope that helps.
Reactions: Mudwing
41,680
Hmmm... thought I'd posted in here, but I guess not.
I'm running 26" Ocelot p350 BigHorn copies. Around 4.5 psi. I favor smooth(er) ride over handling.
