P500 Pioneer 500, What Tire Pressure do you run?
What Tire Pressure do you run on your Pioneer 500? Pick 2 - Front & Rear
  • Front 0-4
    Votes: 11 5.0%
  • Front 5-6
    Votes: 38 17.3%
  • Front 7-8
    Votes: 61 27.7%
  • Front 9-10
    Votes: 104 47.3%
  • Front 11 +
    Votes: 5 2.3%
  • Rear 0-4
    Votes: 8 3.6%
  • Rear 5-6
    Votes: 35 15.9%
  • Rear 7-8
    Votes: 56 25.5%
  • Rear 9-10
    Votes: 92 41.8%
  • Rear 11+
    Votes: 7 3.2%
  • Total voters
    220
SouthGA
SouthGA
61
127
4psi on my 27 Dirt Commanders any more and they scrub the frame on a full turn. They are great tires 27x9x12 /27x11x12
3786
34,174
8 psi on Bighorn 26's.
Reactions: rtn001
haleakala
maui hawaii
Pioneer 500 owners,
What tire pressure do you run?
FYI - Honda recommends 10 psi cold.
Please answer in the poll or talk about it below.
Thanks.
In psi, vote twice Front & Rear, you may change your vote.
Honda recomends:
Front - 10 psi
Rear - 10 psi
Also see:
P1000 - Honda Pioneer 1000 Tire Pressure | The Honda Side by Side Club!
Pioneer 700 Tire Pressure? | The Honda Side by Side Club!
Honda recommends 10 on the 4 ply stock tire on the P500. I have kenda htr and on the kenda site they recommend 7 psi. I initially had my tires at 10 psi but it was too bumpy on rocks. Lowered to 7 psi and much better. The kenda is 8 ply vs 4 ply for the stock tires. My 2 cents.
Reactions: rtn001 and Lburou
Mudder
Mudder
NTC Ambassador of Walls
11,327
84,206
27 Journey bighorn type on 14 in rims at 7-8 psi, but still stiff on rocks. Will try 5 next trip.
Reactions: rtn001
rocmar
rocmar
4,741
5,773
4 CORNERS
I do 12 psi
...was at 10
terrain here differs
alot...in a short distance
....turn up the tunes
.....Alright we're JAMMIN
Reactions: rtn001 and trigger
Curtis
55
76
Mississippi
  2. Do not currently own
4 psi front and rear with AMS 8 ply 26 x 11 x 12 all four corners.
Hello do you have spacers or aftermarket rims with differant offset on your unit to be able to put the 26x11-12 On the front
Reactions: rtn001
rocmar
rocmar
4,741
5,773
4 CORNERS
I got 2" spacers...on all
corners..
Have 26....9 front
11 rear
never had any trouble
JCart
JCart
897
2,024
Kamloops, BC Canada.
Hey Curtis,
Yup I have 12" diameter aftermarket 5-2 offset rims, ITP 212's in black (think that's the model) run them on all corners. The notion is to have the ability to rotate tires so they last longer, greater front floatation and support (soft ground, ride and snow plow). So far have been very pleased with this setup. Steering is not noticeably different then stock except if you are doing a really tight turn around then it's a little labourious. Plans are for e steering at some point but I view that as a luxury and would rather have other mods first. E.g. Exhaust, intake, Dobeck ARF, etc.
Hopefully someone can comment if they've run 26x11x12's using stock rims..... that I don't know. Lastly once I put custom mudflaps on it's much nicer to ride, way less mud in the cab on the window etc.
Cheers,
j
Reactions: rtn001
Curtis
55
76
Mississippi
Do you know off hand the maximum with of you unit I was trying to stay at 50 inch or very close at least due to government trails around hear
Reactions: rtn001
ClarkRN
ClarkRN
17
37
Madison Co. Kentucky
i was riding Wildcat in KY at 10 but backed down t 8. 10 was fine riding the 2 miles to the farm on pavement amd doinfg work there but harsh on the dry trails. 8 psi is what was recommended on the bear claw htr's in 26"
Reactions: rtn001 and ehart814
ehart814
ehart814
1,654
3,643
NWPA
I agree. Don't run them below 8. Especially in the rocks. I knocked a bead off on a rocky trail. Over 1000 miles on my set and I think 8 psi is right for these tires.
Reactions: rtn001
JWB
JWB
2,012
California MD
14" ITPSS312 wheels with 26x9 front and 26x11 rear rip-saw RT's (Sedona) 4 psi front, 5 psi rear. Very stiff tires, and I really think they were engineered for a heavier machine- max load inflation is 18psi for near 800lbs load capacity per tire. I don't load heavy, and 4-5psi gets most of the tread on the ground. Tires were shipped with 12psi, and it was like riding on solid tires- real bad. About 600 miles so far at my pressure setting. They handle and track very well, and are showing no appreciable wear at this point. Traction over stock tires was immediately apparent, and improved noticeably with lower pressure.
