P500 Power steering install
Mudder
Mudder
NTC Ambassador of Walls
11,317
84,077
Thanks guys - I hope it helps some people out.
@Code54, your excellent post has me thinking about placing an order. Sounds like no regrets? I am running 27 inch tires on 2017 on very slow and tight trails.
Update: ordered from Super ATV today, received discount from mentioning Hondasxs.com.
Reactions: Arizona and trigger
Mudder
Mudder
11,317
84,077
Installed EZ power steering today on 2017 P500. Only comment is that my instructions showed motor mounting opposite from earlier post picture. Flat motor housing went up, rounded shoulder side went down. Misleading as the mounting plate has a similar sized hole as the shoulder, but it would not fit (second pic). Also, my red and black power wires came out on the dash side, spoke to tech support, no problem. Other way definitely would not line up. First Pic is from instructions. Like @Code54 said, don't tighten bolts until everything in. Easy steering now.
IMG 0053 IMG 0050
156,597
Installed EZ power steering today on 2017 P500. Only comment is that my instructions showed motor mounting opposite from earlier post picture. Flat motor housing went up, rounded shoulder side went down. Misleading as the mounting plate has a similar sized hole as the shoulder, but it would not fit (first pic). Also, my red and black power wires came out on the dash side, spoke to tech support, no problem. Other way definitely would not line up. Second Pic is from instructions. Like @Code54 said, don't tighten bolts until everything in. Easy steering now.
View attachment 44299 View attachment 44300
How much was this kit? Big difference in steering or what?
Mudder
Mudder
11,317
84,077
$549 after mentioning Hondasxs.com for discount. Huge difference with the 27 inch tires and it was a larger power steering motor than I expected (good thing). FYI..Tapped into the white/black 12 v key hot lead from the four slot accessory plug for the small while wire, and already had the heavier main red power lead under the hood from the earlier winch install.
IMG 0052
Mudder
Mudder
11,317
84,077
CAUTION..Lesson learned as I had to remove and reinstall the motor, ...leave these three 13 mm head bolts untouched. I first removed them for the mounting plate install on the opposite side, but later found other bolts in the box (10 mm heads). The 13 mm bolts seal the internals, as you can see a shaft inside. This is the side to face downward towards the rack and pinion. Interested if there was a change since @Code54 did his photos. FYI, update after a few days.. wife drove it and said why didn't I do this sooner!
Ps. Still fine one week later.
IMG 0054
W
WillB
41
69
Churchill,Ontario
So no worries on electric output on the P5? Wont bother with it on my Polaris, not enough juice to run everything.
208,013
Thought I would come over and pick on you piss ant P 500 owners, JUST KIDDING! I would like to have a P5. They are great machines, there hell to keep up in the tight woods. PS is great. I'm glad it working for you.
Mudder
Mudder
11,317
84,077
@Chooglin , Package weight listed about 24 lbs., but lost a little weight on the wallet!
Reactions: Chooglin
Mudder
Mudder
11,317
84,077
@trigger , it will help those sore arms after shoveling that white stuff you guys have up there!
Reactions: rocmar and trigger
208,013
You just gotta keep bringing it up don't you Mudder?
I've considered putting one in and just keep forgetting about it and then...peer pressure! :D
It's a lot safer.
You guys are killing me, I had it in the cart last night. Tried to live chat with someone at SuperATV but it was after hours and no one was available. Wanted to negotiate price but...I'll try to forget about it again. o_O
10% code - HONDAFORUM
Reactions: Mudder and trigger
rocmar
rocmar
4,741
5,773
4 CORNERS
Thought maybe...you came over here...
To borrow some tools... cause your s***
was broke down....again
haha..
just kidding
208,013
haha..
just kidding
Nothing broke down but my tiller and I need it, any volunteers?
Reactions: rocmar
