P500 Power steering install
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Just received mine from SuperATV and have a question for those that have this installed... I was thinking about powering it off a toggle so that during winching I can divert all power to the winch by shutting everything off. Sooo... “Could this approach hurt the Power Steering if I would forget to turn it back on? And what if I switch it on while already in motion?o_O
Chooglin
This really isn't necessary, the power steering unit only uses power when the steering wheel is being turned. I would think in most cases , while using the winch , you won't be turning the steering wheel much (unless you plow with it).
To answer your question though , I don't know if it would cause damage or not but I wouldn't do it.
Mudder
Mudder
NTC Ambassador of Walls
11,317
84,077
Agree with above, only uses power when turning, never had a problem. Always free wheel the winch for set up to minimize run time during pull. But I do not plow.
Chuckie3
216
408
New Fairfield ct
Should have never joined sxs club spending to much $ listening to u guys .want power steering but plow a lot of snow do u think it should be ok your thoughts
Reactions: trigger and Neohio
Mudder
Mudder
11,317
84,077
@trigger ? Plow and PS?
Reactions: trigger
156,597
Lol, now you're an official member of the club! Plowing is one of the main reasons I added PS. I've had this machine is some pretty tight binds and have never had the slightest issue with the PS. Makes it more capable if anything. ;)
Reactions: Mudder
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I found this video to support the discussion on whether or not the power steering unit would be damaged...
solrus
solrus
1,629
2,511
Montana
I'm doing second p500 unit PS install this weekend. Everything on backorder at Rocky mountain at, so had to buy more expensive unit.
Sent from my Moto Z (2) using Tapatalk
U
uconn411
160
255
CT
I have all my extra electronics fused and then on 1 large kill switch. When Plowing I have held the power steering too long and too hard in one direction and it has shut down. I flip my main switch and it all powers on again. The PS does a good job not hurting itself. I have the tusk unit.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thank you! Great example of what I was looking for! Still want to hear from others keep the comments coming:)
Mudder
Mudder
11,317
84,077
@ToddH , didn’t you just order PS??
Reactions: Mudwing
Todd627
Todd627
56,285
615,057
MI
Yes, should be here today. Hopefully will have circuit breaker, fuse block, & wEnch all wired up and get the power steering installed also this weekend.
Plus, another surprise.......:D
Todd627
Todd627
56,285
615,057
MI
Like a 66" surprise?
That's not the surprise, I didn't hide that I ordered a plow kit from Richard (and the plow will be here today BTW :D).....
Reactions: Mudwing and trigger
Todd627
Todd627
56,285
615,057
MI
I cannot get the mounting plate to lay flat on the cross member its like the lower shat is an inch too long.
Reactions: Mudwing
Todd627
Todd627
56,285
615,057
MI
On the upper shaft, do you put the adjustable end up or down?
Reactions: Mudwing
nctrailboss
nctrailboss
440
1,454
north carolina
I had the same problem.I cured it by not using the pinch bolts supplied,but instead put 1/4" grade 8 bolts in their place.It allows a small amount of extra slide on the splines.Leave those pinch bolts on the joints loose until everything else is tight.
Reactions: Mudder
Todd627
Todd627
56,285
615,057
MI
Thanks @nctrailboss that worked ;)
