P1000m5 shutting off while driving.
rossjames155
10
19
North Jefferson state
My 2016 p1k-5 with 4500 miles just started randomly shutting off while driving. Seems to me it only does it going up hill under hard load. It’ll just completely shut off, once it’s shut down, the oil light comes on and the check engine light flashes. Turn the key off and back on and it runs like nothing happened. And yes, it has plenty of oil. Does anyone have a clue? Thanks in advance!
Reactions: Lady01 and BWAF
RickMaynard
101
121
Arkansas
Mine did something similar, but instead of shutting off, it would slow to idle and rpm’s would surge terribly. Possible cause was during all my electronic hookups, I put the (+) battery lead back on top of the other electronic stuff on my battery and my dealer thinks the important electronic stuff wasn’t getting enough power and causing things to go hay wire.
rossjames155
10
19
I’ll have to look in to that. Mine just flat out shuts off. Screen stays lit up
0860silverado
947
1,817
louisiana
Mine did the same. Turns out it was a bad crimp job on an injector. It's a somewhat common issue on these machines. I fixed mine myself with help from other members" suggestions. Good luck and let us know what you find!
rossjames155
10
19
Thanks for the info! What did you do to remedy the crimp on the injector? I would bet that is exactly what the issue is, because it is so intermittent!
Neohio
Neohio
Beast of the East
13,424
65,865
Painesville Ohio
@rossjames155
Here is the thread @0860silverado was referencing
P1000 - PGM-FI DTC 12/13 (Fuel Injector)
Your machine is a '16, so it may be the same thing. I believe this issue was corrected by Honda in later model years. If you need any help with it, please let me know, or ask in the thread.
sic
In My 2020 1000-3 I was sliding around in the snow and gave it gas going up a big icy hill and it shut off in similar style to yours and it's only got 35 miles
Reactions: Lady01
Hartman376
Askov mn
2200 miles on mine and it just started doing the same thing. Not sure the issue
Reactions: Lady01
Cpedigo81
Lafayette Tn
Same thing with mine. It’s a 2018. Done fine a couple of weeks then back to doing it now while driving down backroads. Have you had any luck diagnosing yours?
Reactions: Lady01
P1K5Dave
P1K5Dave
2,181
8,164
Petoskey, MI
Do a forum search on injector wires as your starting point. If it's just shutting down randomly, then starts right back up, that's likely your problem.
slowdryrider
slowdryrider
564
757
Canada
Read the below post and see if cleaning up your shift motor would be something that would help you. If the machine , Trans doesn't shift down the computer will shut the motor down to keep it from lugging >>
Reactions: 05Willys and Lady01
57,052
Problem fixed. Replaced both injector harnesses and hasn’t skipped a beat. Finally seen it flash the one long and three short check engine lights after it died going down the driveway 3 times within 20 feet apart 🤦🏻‍♂️
Glad you figured it out. Thanks for letting us know what resolved the issue!
