P1000 Solved - 2016 Pioneer 1000-5 Stalls when Slowing down from 35mph/Downshifting
aareed
aareed
19
58
Texas
I recently purchased a 2016 Pioneer 1000-5 Deluxe with about 3000 miles on it. It has been stalling several times when riding and on trails. Seems to happen after it has been running for over 30 minutes and only on warmer days 85+. (I rode the same trails for four hours previously in cooler temps (60's) with absolutely no problem)
Originally noticed it when slowing to a stop, it would die. Turn the key off and immediately restarted. More recently I have noticed it riding on trails and seems to happen when I let off of the accelerator. There are no flashing codes on the dash that I have been able to determine, and I have let it sit for a minute before turning the key off then back on.
I replaced both fuel injector harnesses this past week, took it for a 30 minute slow drive (10 mph) and it ran fine. Then took it out on a back road and immediately started having problems. Running below 20mph it did fine. But as soon as I slow from 35-40 mph it dies, rolls to a stop, I can hear the transmission downshifting from 6 to 1 once it stops, and it will immediately restart.
Any ideas what might be causing this?
104,887
Welcome from Michigan!
Bad fuel, crap in the tank. Drain it and clean it good. Sounds like shes starving. Ethanol chitty fuel will rake havoc on these systems
also…your first post, we have an unwritten bible verse around here when you come on its called…
PICS OR IT DIDNT HAPPEN! ;)
Todd627
Todd627
56,159
613,950
MI
Another welcome from The Great Lakes State.
I agree with @Remington about it sounding like a fuel issue.
Also agree with him about.....pics or it didn't happen ;)
#NTC
aareed
aareed
19
58
Texas
#NTC
Oh it has happened, several times. . . Which Pic do you want to see? Dash? Me sitting stopped pounding my head against the steering wheel? Could be bad gas, been running Non-Ethanol, but could definitely be crap in the tank. Why would it die on deceleration though? I can run it 60+mph on a cool day fine, just happens when it is warm/hot out.
56,531
Check your spark arrestor
TripleB
TripleB
11,663
99,042
Caryville, Tennessee
I wanna see the pic of you banging your head on the steering wheel.
104,887
That would be awesome to see one of those pics!
But seriously…POIDH is just a pic of your machine! Working or not.
its a verification validation you see! ;) Lol
aareed
aareed
19
58
Texas
I took it out for a long slow ride again today for about 45 minutes, running about 15mph most of the time. ran fine, put it up on a road to check it . I started at the beginning checking to see if it would die/stall when slowing down from 45 (releasing the accelerator only). No problems at the beginning. Rode some trails for about 45 minutes averaging 15mph most of the time. Tried it again, first slowing from 30 down, no problem, then from 35 down, no problem, then 40 down and it died. I recorded this time and I see 2 short flashes of the check in engine light. First is immediately when it dies, then a delay and a second short flash. I apparently cannot upload a video so here are a couple of screen shots.
The first is right before it dies, going 43mph. The second is when it does, the H fades on the dash, temp drops to 1 bar and the speedometer reports incorrectly 28mph. After that the H returns Speedometer begins reporting correctly but temp still shows 1 bar.
I did clean the Spark arrester, the bottom was a little dirty (10% clogged), but should have had plenty of ventilation all around the sides which was clean.
IMG 2240
Reactions: ChadD and Lady01
TripleB
TripleB
11,663
99,042
Upload the video to YouTube and share the link here.
E
Ericthered
Eric The Red
271
522
Sparks, NV
Check your engine grounds! This beast loves full power, or it just lays down and dies. Tighten the 3 grounds on drivers side of engine around filters area. Tighten by hand with wrench, don't just wiggle. Did mine 3 years ago, no issues since!
56,531
Not sure what you mean. There is nothing that wouldnt normally be there.
A lot of people cram tools, bags, ammo cans, etc in there. Was just curious if it was filled up with stuff and something might be retaining heat when you ran it harder. I agree with the others on the grounds if you haven't checked them.
slowdryrider
slowdryrider
563
756
Canada
Here is your problem. I've had similair problems with mine in the winter. This is what I had to do to mine and its been working since then. This doesn't cost you anything. Go to the back right side of the motor you'll see the Electric shift motor. Remove it take it apart and you'll find that the armature is black looking.Clean it up with some fine sandpaper . The brushes are mounted inside the black plastic housing so make sure that there moving freely . Putting it back together isn't that hard if you place the brushes over the armature first . Hold onto the shaft that sticks out and hold onto it pretty good so that you keep the brush holder and brushes from coming off the end. The magnetic force of the motor housing is going to want to pull the armature back into the motor housing. What happens is that the armature gets carboned up and the 5 volts that is used to activate the motor to turn can't overcome the build up of carbon. Try it and see what happens . Let me know if this works for you . It did fix my problem with mine.
Just adding this in for those who aren't sure what the electric shift motor does.
FYI The electric shift motor does the actual changing of the gears so . When the shift motor isn't working properly and your slowing down. and it doesn't downshift The computer get confused and and shuts down the motor . This is to prevent the motor from lugging.
aareed
aareed
19
58
Texas
Thanks for all the feedback, I have checked the Ground wires on the motor they are all tight, I will check the Electric Shift motor next.
HBarlow
HBarlow
1,618
6,009
Daniels, WV
Your description of symptoms sounds like your engine won't idle without stalling. I agree with others above. it's usually caused by old ethanol gasoline left in the tank, lines, and injectors.
I would try running a couple of bottles of Chevron Techron or premium Chevron gasoline which contains Techron through upir engine in prescribed amounts.
Techron can usually be found in auto parts stores such as Autozone or in Walmart.
aareed
aareed
19
58
Texas
No. Not at all. The engine runs and idles fine. Just stalls when slowing down from 35-45mph after the machine has been running for a while and on a warm day.
