Super atv rhino axles for Pioneer 700
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Hey guys, I just emailed super atv yesterday about when and if they would be offering rhino axles for the pioneer. For those that don't know, rhino axles is the brand name of the axle and has nothing to do with the Yamaha rhino! Anyway they told me rear axles would be available next week sometime and front axles "hopefully" next month. Just wanted to let everyone know as this is something I've been on the lookout for for awhile. Not because I break stock axles just because I like to know my drivetrain is bulletproof!
63,545
Great news, considering the OEM axles have been on backorder.
Knowing that several people have already broken the fronts with oem wheels... It's good to know there is a better replacement not far from release.
Keep tabs and let us know if u find out anything.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Still nothing on super atv's website. I'm checking often and ill post when they appear
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Just an update- Emailed super atv again and they told me parts would be on the website "very soon". Not quite sure what that means so just keeping fingers crossed.
scott
scott
1,212
1,354
lyman, South Carolina
Is the rear axles the same. Thinking i might buy one rinho axle for a back up. And is front the same? Can i buy one rear and one front and use on either right or left.
63,545
Nope, There all 4 different. And that sucks. lol
scott
scott
1,212
1,354
So I got to buy all 4 dang it. Oh got my cv guards from RMP on and the boot replaced. But I saw I got a little bitty pin hole on right rear boot so will change them out next week. It sucks changing them boots out.
Ha just buy a whole set of Rhino Axles....Then you have a set of spares!
63,545
For a pin hole... Clean it up good, scruff it up some, decrease it, and some black RTV on it. Like it never happened.
scott
scott
1,212
1,354
You talking about the Permatex Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 3.35 oz. Tube Had to Google it. I got to order some also. Or what kind you use. also hondasxs you know anyone around here that is going to wind rock that could pull my sxs i can get a big 20' or 28' trailer. Thats if i can't get a truck or my jeep fixed in time. I'll just stay in my tent.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
That's the plan if they will ever get them up on their website!
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Big news! The wait is over, super atv has rhino axles for the pioneer (front and rear) available for purchase on the website, $200 per axle!
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I thought I would post the product description, as I found it informative-
29e3d17b71298f161456d85b356164f2
Honda Pioneer 700 Heavy Duty Axle
Will Fit:
Honda Pioneer 700 : 2014+
Honda Pioneer 700-4 : 2014+
To ensure the highest quality and performance, Rhino Brand Axles are made from Heavy-Duty 4340 Chromoly Steel, one of the industry’s strongest materials. This creates an excellent strength-to-weight ratio for these heavy-duty axles. Along with being significantly stronger than other axles, Rhino Brand Axles can operate at huge angles. Generally after a lift kit or larger tires are added OEM axles are not up to the task of handling the added pressure. This often leads to the weakening and eventual breakage of the axles. Rhino Brand Axles are engineered to have larger shafts and CVs making them able to handle these extreme angles. Not only can they handle the angle pressure, Rhino Brand Axles perform exceptionally well under the stress of high-powered motors and aggressive tires. These axles have proven themselves again and again and can withstand the test of the most intense riding.
Axle orientation is the same as if you are sitting in the bike. (Driver's side is left, Passenger side is right).
We offer a 1 year warranty on all RHINO Brand axles.
http://www.superatv.com/Honda-Pioneer-700-Axles-Stock-Length-Rhino-P11872C1524.aspx
I'll probably be replacing them as they break, if they break.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I found another axle option, thought I'd share-
Demon Heavy Duty Axles for Honda Pioneer 700 / 700 4: SideBySideStuff.com
They are available for the 500 as well. Don't know if they're any better than the rhinos but nice to have options that are priced nearly the same. I'm thinking of doing this upgrade in stages. Do the rear first then the front or maybe the other way around, can't decide which end needs them more. Maybe the front then I could run 4 wheel lock and not have to be careful! What do you guys think?
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
Can i ask why you would replace something that hasnt broken yet? I mean order one or two in case the stock ones break but I have been surprised by the durability of some stock parts. Not condemning, just asking.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
It's mostly a preventative measure. The rhinos are stronger and capable of handling extreme angles. Once we lift our machines, add power, and start adding larger tires, we are asking the stock axles to do things they weren't designed to do. With all that said, the stock axles have proven to be quite durable, with only a few reports of breakage (usually in 4 wheel lock). Maybe I would never break a stock one, but as I continue to modify my machine I don't want to have to wonder.....and I DONT want to find out 50 miles from my truck!!
Reactions: joeymt33
