P1000 1000-5 Accessories install
Trailrider
Trailrider
37
34
Alabama
What are you guys writing your led lights to. Are you installing a fuse box or going into the factory. If factory which one. I plan to install light bar, and 4 led pods. Also do I need a second battery for those and a winch. Sorry if this has been asked before. New to the forum and new pioneer owner lol. Thanks in advance.
Reactions: TimG and sharp
69,244
I used a fuse panel and 2nd battery.
Reactions: TheHoover
TheHoover
TheHoover
221
694
PNW
hondasxs.com
As Tim Taylor said it.
“MORE POWER!”
I would say your okay on factory until you mentioned the winch.. I’m getting second battery setup(battery, fuse panel, isolator) mainly to leave factory setup alone. Also nobody needs to worry about turning the radio off when I pass out. Peace of mind. Lol.
69,244
“MORE POWER!”
Amen!
Trailrider
Trailrider
37
34
Alabama
Thanks for the replies what is a good secondary fuse block. And if I do the fuse block do I need to do relays for each set of pods and lightbar.
MTLuckyDan
38
51
US
There's a sticky on Pioneer 1000 General discussion page that has the information you're looking for as well as dozens of posts. Several good alternatives depending on your specific needs.
Sent from my P00I using Tapatalk
Reactions: Remington
Neohio
Neohio
Beast of the East
17,743
85,578
Painesville Ohio
Using relays will depend on the amp draw of the lights, as well as the amp rating of the switches you use.
If you are using offshore switches, I personally would limit them to 10a, if the load is greater than 10a on that switch. Use a relay.
If you are going to use a legit Carling tech switch. They are rated at 20a and I would not hesitate using them at the full load.
