P1000 1000-5 Parking brake ideas
Tramguage1
Tramguage1
Texan
7,606
31,529
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I think you could make something work drilling in the stock pedal bracket but I didn't want to modify mine.
How big are your feet? I haven't had any complaints that mine is in the way
Size 12's but I must put my foot up higher on the pedal. I mocked up a bracket and I hit it with the toe of my boot. also it was a little tough to work the lever with the under dash storage. I just don't think it will work for me. its a great simple design. I'm in for making some up if members need them.
how is it bolted to the factory bracket? did you use flat washers and just use that wearied shaped opening?
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,231
Oshkosh, Wi
I used 1/4-20 bolts and washers in the stock cut out. I set the brake with the bolts loose and then tightened then up with the bolts bottomed back in the slots
Reactions: Tramguage1
Tramguage1
Tramguage1
Texan
7,606
31,529
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
OK I was wondering if me 17 LE was different.
Hay guys! I looked at this a little yesterday. I must have big feet!!! the position of the bracket was in the way when I put my foot on the pedal. I was doing a little thinking on how to come up with a spring release pawl type stop. Or why cant you just drill a hole in the existing bracket and install the lever?
How many are interested in this or @Delton type brackets? ill make up some if you guys want them.
That’s why I cut my stock bracket and angled my parking brake bracket up.. I wear rubber boots a lot and mine doesn’t get in the way.
It’s hard to see in the pic but it’s substantially raised in the front.
64A32E83 DF5D 4B8B 84E9 F3A31537A9CC 98EB23EF 981E 45F5 9A4F EB84815832DA
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I haven't hit my bracket once so far. Did you get in touch with Don? His doesn't require a bracket at all.
silverstreak
14
10
Morgan Hill, Ca
Has this gone anywhere? Has anyone made any of these to sell? I have friends with Honda's that would also be interested, I know I am for sure.
Reactions: BWAF
Tramguage1
Tramguage1
Texan
7,606
31,529
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
How many you need for sure? I could probably help ya out.
silverstreak
14
10
Morgan Hill, Ca
One for sure for myself. I will have to ask around and see if my friends want them, I have 4 friends with the p-1000 and we have talked about a parking brake for these. Even if I could have someone make a bracket and tell me what type of plunger I need to buy.
Tramguage1
Tramguage1
Texan
7,606
31,529
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I have 1 of the clamps already. I'l look up the link to the clamp. Find out how many you need and I'll work with ya.
DDDonkey
If you shoot me a price for a complete unit, shipped I would be interested in one.
Tramguage1
Tramguage1
Texan
7,606
31,529
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
On the road back from Mulberry now, I'll PM you my # and we can discuss
crazychris
crazychris
249
532
redfeild arkansas
same here interested in buying one instead of making one. with base ball season starting for my oldest I am busy busy. wished we could of came to the mulberry take over. we will likely be there next year.
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,231
Oshkosh, Wi
I was looking into material for a single bent piece but I decided not to make more. I can make one of most things quite easy but haven't had time for making a lot of anything lately.
silverstreak
14
10
Morgan Hill, Ca
I will take one right now, and maybe 2 and as many as 5, as soon as I talk with the others. Let me know.
Tramguage1
Tramguage1
Texan
7,606
31,529
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Ok guys just keep posting I'll revisit and come up with a $ figure
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I can relate to this. I love creating stuff but finding time to make copies for others is hard.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
If y'all get @drfubar to post which model he got, no bracket is necessary.
Reactions: drfubar
