P1000m5 1000-5 Tie Down Straps
  • Thread starter Rackpioneer1000-5
  • Start date
Rackpioneer1000-5
Rackpioneer1000-5
9
19
Ross
On the way out yesterday I located the tie downs as shown in the Honda owners manual. Basically, locating on the roll cage. It trailed aweful and was moving so much one of the straps came loose.
On the way back I strapped to the A arms. It trailered great and didn't move. Is this the correct location to strap? On the roll cage and bumper just moved too much. 63600c8a5cbc4b8fa326d059dc8081a7
popeye
popeye
3,275
14,644
kapowsin, Wa
I never liked tieing off to "sprung" parts of a rig either. Way more stable and safe when going to the lower parts of the rig.
Jshell3
I chain thru the front bumper. Then throw a good ratchet across the floorboards and go at it until it squats about an inch.
No problems.
nbomar
nbomar
4,416
17,854
Springdale, AR
I tie to front lower arms then to the rear hitch. I I try not to compress suspension much when strapping. I also use cargo buckle straps so if it does bounce it just tightens the strap.
I was ratchet strapping the rear too.. now I have cut to length chains for the rear that hook into the rear tie points I've added. This allows for the perfect weight distribution every time.
IMG 2654 IMG 2655 IMG 2804 IMG 3203
Reactions: sharp and Jshell3
Pjohnson
Pjohnson
6
20
Fairbanks, AK
I use two strap son the front a-arms and run a strap behind the receiver in the back. Works great, no movement or loosening of straps.
Jshell3
View attachment 39506 View attachment 39507 View attachment 39508 View attachment 39509
Hey... can anyone show me / tell me about adding shackles to the stock front end.
I'm thinking about adding something up there to keep from threading my chains through the bumper for trailering.
Like @JTW has here.
More pics, plz.
Jshell3
I think it would be helpful for being pulled out / me pulling someone out, too.
Twice this weekend I had to turn around 180 in the mud to hook off my back rec'r hitch. Getting folks unstuck.
Like @JTW has here.
More pics, plz.
Mine are just half inch D-rings from Amazon.. I drilled two holes in the bumper and used a piece of bar stock with matching holes as a plate for the back. Mine came in a pack of 4 so I bought 1 3/4" exhaust clamps and made tie points for the rear.
Reactions: CumminsPusher
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
IMG 20170225 145307296
Similar to what the manual shows. I bought straps with hoops sewn in them to hook the strap hook back to the strap after looping around the bumper
Reactions: Jshell3
popeye
popeye
3,275
14,644
kapowsin, Wa
You might want to be carefull if pulling a stuck buddy out tied off to the front of you. With reverse being a higher ratio gear than first gear you could be straining the 1st/reverse clutch a little more than if you were pulling them forward. Just my .02cents
Only if you're letting it slip.
Reactions: Jshell3
allgm1
allgm1
1,049
1,484
New Hampshire
Not a p1k here, but a 700, I prefer straps, cinch it down and its not flopping around, yeah I might wear a little paint off but the mud will hide it.
20150819 133004 zps2vcqsygd
20150819 132951 zpspsfxou1j
