BOX1 - TEST
Talon 1000R Narrowed
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
So my thought is with 15"or 16" wheels offset in how narrow can the talon be made .The suspension would be great but do want something that wide .Thoughts
265,435
I do believe I read that the OEM wheel offset is 30mm front and 50mm rear, that is with 6" wheel width front and 8" wheel width rear.
Of available aftermarket options, most typical offerings are 7" wide wheels, and a rare few (STI wheels like HD3) offer a 6"+1" offset, that 1" - 26mm (close approximation) the typical popular offsets are 5+2 & 4+3.
So best case scenario if using OEM width tires you might only narrow the front end by 1/2" overall and narrow the rear by 2.25".
If you add wider tires such as 30x10x15 etc. you will actually get wider that 68.5" not narrower.
BWAF
BWAF
8,857
42,437
Carthage MO
That's kind of what I thought 6+1 is tough to come by .I was thinking 31x10.5 Baja claws. The trials I ride factory probably to wide be awhile anyway. With a broken hand lots of time to dream
265,435
If you put that size tire on the front, it could be as much as 2" wider overall than OEM. Likely only 1" wider overall with 6+1 offset wheels.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
So 69.5
BWAF
BWAF
8,857
42,437
Carthage MO
Think I'm 64" pioneer 1000-5
265,435
So 69.5
Yes, likely outcome.
What wheel offset and tire size? My P1K was 64" on front with 28x10x14 Roctanes on 6+1 STI HD3 rims, rear was only 62" with that setup too.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
30mm offset hd9 and 235-75-15 .1"spacers in rear F844908fc78fd2fa6813bb0354bbb66a790bfb927a0cde164cd00a1c2b65fa9d3d3e1a3d43171b5447030af10a43f9a5
BWAF
BWAF
8,857
42,437
Carthage MO
Well that's about as close as you can get, 30mm being just over 1 1/8" offset.
Pretty much forgot what they were had to go back and look :)
Reactions: Mopower58
BOX2
box3 - TEST
