hondabob
Still runs just like a new one. Same with the suspension. My Fox Shocks have about 13,000 miles on them. I replaced the shift cable and exhaust rubber mount a little before 12,000 miles. When the steel sleeve separates from the cable housing it won’t shift into low range. The sleeve is crimped into the cable housing so it will move a little. I needed low range so I removed the seat and shifted the lever on the trans by hand. The exhaust mount rubber is the one closest to the engine so its gets more heat then the other rubber mounts. My Pioneer 1000-3 set a high standard. The maintenance is easy too.
