P1000m5 2” Wheel Spacers
ecom101
ecom101
15
44
Kelowna, BC
ecommediagroup.com
I recently added 2” rear wheel spacers and mover my previously installed 1” spacers to the front to provide better stability and a wider-looking stance.
The look great on my Trail Edition and the RB3 billeted aluminum spacers are top quality.
5E4F7D99 3D13 48F3 8E8D 053ED850D8E8 96CCE86D 9C1B 4D25 B45F 4C25564B8469 74C8CA6F DD22 4B87 A9D2 C92BDFC64D63 F3B57AB6 719D 4B22 B532 064523B30E28 BE955577 37C9 4C19 9479 02B9D47DE269 580B5774 4ECB 4CFB 967C DD00E8B35DDF 14AC24B5 9054 40A4 A08D 16B7D63DE450
Jankyeye
Jankyeye
558
2,508
Tampa, Fl.
Are those stock wheels/tires or did you go with the same size on all 4?
157,872
Reactions: Rayger143
SaltwaterSlick
224
946
Southeast Texas
They are stock wheels with new BFG KM3 rubber - 29” x 11 on rear and 29” x 9’s on front.
How much pressure you running in those BFG's... I have the exact same tires on my P1K5 with a pretty good size front bumper/guard and winch mount, big basket up front over the hood and an all aluminum top... Been playing around with mine a bit, but last night I took a ride with 18 psi all around and I'm liking that feel and ride...
What has been your experience?
ecom101
ecom101
15
44
Kelowna, BC
ecommediagroup.com
The dealer just installed them and I haven't even checked the PSI but I imagine it's what is stated on the tire. The first time out there was definitely some break-in feeling needed, as the second time out felt much better. They do feel slightly over-inflated so you are liking 18 psi? I will try that this weekend. Thanks for the advice.
SaltwaterSlick
224
946
Southeast Texas
Where I hunt (buggy is primarily a farm and hunting vehicle), in South Texas, we have a lot of thorny brush and mesquite trees, cactus, as well as lots of rock, mostly loose rocks as opposed to large boulders/mountain like solid rock... I have the BFG tires on my ranch truck (Chebby Z71-Offroad), and they have performed well there... With 18 psi, the tires stand up straight with little to no sidewall bulge. Most of our flats/punctures come from brush through the sidewall if it is soft/bulging... You might be OK with 12-15 psi if you're wanting a soft ride and don't have to contend with sidewall punctures... If your dealer pumped up to their recommendation, you've probably got 30 or more psi in them... Mine rode like a tank like that!! I put it on jack stands yesterday and let the air out and pumped in 1/2 gallon of Multi-Seal HD2500 tire protectant in each one, then pumped back up to the 18 psi... Will see how that works out... The multi-seal virtually eliminates puncture flats, even by hole punctures...
