P500 2+5 Offset??? With 30x11-12 Interforce?
Splorin
320
904
Maine
The 5-2/4-3 combo will be fine. Probably more reasonable too. Trim frame as needed. If you don't like crap being tossed at ya then Mudbusters may be in your future. Dry this spring which is why my wides stayed on longer but even then rocks get picked up and whistle by your head. Honey's not thrilled they're still on. Worn out 24's back on Monday for 'golf cart/beach' season.
I was curious about the actual weight of those 12x12's?????
194,469
If I were you and you were me what offset would you choose? I've got 4+3 and 5+2 Deltas on hand, and same 10 and 12 x 28 Mudlite XL. Would be much easier to exchange now than to have them mounted and want to change offset again. But then again, at this point, what's another hundred bucks?
If you're able to exchange them, a lot of companies won't take them back once they've been mounted.
Reactions: Bigtee
Splorin
320
904
Maine
trigger, how bad did your 28" BHs rub pre-arm? I've considered those cuz they run 'wide' for a 10". Certain 2.0s just look 'bigger'. At a dealer last week and two new CanAms were next to each other. One with 27x9x14 2.0s on the front and the 1000 Turbo had 29x9x14. Looked like adult and child. You could hide the 27s in the 29s.
rustyneversleeps
rustyneversleeps
384
1,847
Montana
I'm aware, that was my point.
Pretty well convinced that I'm going to run these, unless someone steps in to change me mind.
Curious to see the pics and clearance...
194,469
Never even tried 28's until I added A arms, they'll rub.
K
kyote
66
241
La Porte TX
Quick ride around the neighborhood, happy to report that there is no rub full lock right and very slight full lock left, not enough to warrant frames mod at this point, we will see after a serious trail ride. PXL 20210530 162239576PXL 20210530 162256944
Reactions: Mudwing and Bigtee
