![UKNB](/data/avatars/m/7/7524.jpg?1493086418)
How can I tell the difference between the 2 piece Hard Coat and the 2 piece Polycarbonate windshield after it has been installed? Is it obvious?
If I remember correctly the hard coat has a black out line on it. The lower portion is not hard coated...Even though it's says it isHow can I tell the difference between the 2 piece Hard Coat and the 2 piece Polycarbonate windshield after it has been installed? Is it obvious?
Honda was definitely misleading on this. I'm pissed about it after paying $500. I'm pretty sure Honda won't sell me another windshield after that experience.
Hardcoat, no circular scratches or any after scrubbing.How can I tell the difference between the 2 piece Hard Coat and the 2 piece Polycarbonate windshield after it has been installed? Is it obvious?
Alumalite Armor makes a tip out glass windshield for the P1000 housed in an aluminum frame. No scratches and can add the windshield wiper option if desired. It tips out 2" or 4"
Compare
Tip out Windshield Enclosure, Made from 3/32 aluminum with stylish re-enforcing bends that makes it extremely rigid. Corners and transitions are welded so there are no exposed seams. Exposed edges have vinyl edge protectors. All parts are powder coated with a flat black finish that matches roll cage. The Tip-out windshield Includes DOT certified safety glass which locks down water and air tight when closed. It can be tipped out in two positions of 2" or 4" to allow for air flow. The glass frame can also be removed easily and quickly when you don't want a windshield by removing the 2 hinge bolts and unlatching the latches. The strong, light weight aluminum frame mounts securely to the roll cage in minutes with roll bar clamps and seals tightly to the hood and roll cage so you have no rattles and leaks along the hood.
Lmao.. they smelt it out of virgin hair!!! Do you know how hard it is to find virgins these days!!?$1900? Really? REALLY?? Does that come with KY? Half that would still be ridiculous.
Must be in rupees or yen or something.
Is the aluminum produced onsite by house elves?
I wonder if it will work ok with the factory roofThey are very weird on the website for checking pricing. For $1900 that is the tip out windshield, Aluminum Roof, Aluminum / glass rear panel combo (For Honda equivalent that would be $1500 for the three pieces)
The windshield is $790 for tip out, $690 fixed
Compare <<<< This link is jacked, after clicking scroll below to FRONT WINDOW ONLY
Probably just have to call and ask but just eyeballing it compared to the Honda glass windshield w/steel frame I have, I say yes as it all looks flush at top, just don't know about the clamps used on Honda roof across the front.I wonder if it will work ok with the factory roof
That was my thought. Going to look into later. Gotta Wear out my factory tilt first.Probably just have to call and ask but just eyeballing it compared to the Honda glass windshield w/steel frame I have, I say yes as it all looks flush at top.
What I like other than the tip out feature is pull 2 pins and the whole glass panel comes off.
