Tropicalfruitfarm
Drove the 700 around the farm today. Everything started out fine. Made multiple trips back to shed, and on one trip I added about 3 gallons of gas. On a trip back to the shed, it sputtered but recovered and was able to drive to shed. Then it wouldn't start. Battery is fine, it just wont turn over. Tried stepping on brake, shifting everything. I have the seat belt permanently connected as I typically don't use it. Nothing would get it to turn over. I checked relays and fuses and pulled one fuse out and put it back in.
Then I started to get weird things on the dash board, so I thought I would disconnect the battery to "reset" everything. Well, after doing that, the starter wouldn't even kick in! So then I tried to jump start it, no luck. So I left it for a while and tried to start it, I was back to square one, battery ( I have two) appeared to be fine and engage the starter, bit it just wouldn't turn over. I can't imagine the fuel was bad, it's ethanol free and purchased recently. I have about two hours on it after the recent dealer 20 hour maintenance work.
Any thoughts or things to try?
