Yeah, I had the same issue. Adjust it again, the rear linkage may be too tight (or loose, I forget). I've noticed that the subtrans will go into 4WD (and the front diff could lock too), but the indicator will only show if the rear diff is locked first; it appears to be progressive - Turf>2WD>4WD>4Lock.
