P1000m5 2018 1000-5 leaning to the left
crewcabrob
crewcabrob
1,029
4,044
Omaha
adult friend finder!🤣 my p500 leans on the right side slightly. thinking a-arms on one side are over torqued.
Funny, I have been wondering why my P520 leans to the right. Wasn't sure if it was just mine or all P500/520s. I thought it leaned because of fuel. I keep a full tank and fill it after each ride.
Nothing political here going on... not even sure I watched the TV so I don't even know where I would land these days...
Rob
LilRedDonkey
LilRedDonkey
180
614
cheesyland
Rob
could be that!!!
Reactions: robj067 and ChadD
P
Papamac
Goodyear, Arizona
  1. Talon R LV
Mine has been doing the same from day one. I have a 2024 Talon R4 LV. Im going to jack mine up front then rear take height measurements then lower it and check height again to see what the sag is on all four corners
DRZRon1
DRZRon1
1,457
4,449
PA
huh?
Should just measure on a flat surface the 4 corners and set ride height from there?
I’m not so sure what position the LV bleeds off at with zero power
Hello_Darkness
Hello_Darkness
690
2,806
Just to the right of nowhere
If you jack up a LV it won't settle until the unit is started and moved in gear. It will settle some with just the key on, but not fully.
