2018 Honda Pioneer Snow Plow Buyers guide! Honda Pioneer 500, 700, and 1000!
67,170
Plow
WINTER IS COMING!!!
and soon the winds will turn and leave behind a thick blanket of snow. Finding the best UTV snow plow is a challenging process that takes time to weight out all the options. The aftermarket scene offers many different types from the top of the line with a built-in hydraulic tilt to the basic blade for that once a year use.
There are several things to consider when choosing a blade.
Blade Width.
The blade must be wide enough to extend the wheel track of your Pioneer. Choosing one too shot will make it awkward and cause you to plow unlevel.
We recommend no less than the following plow sizes for your Honda Pioneer!
Weight.
You must consider the overall weight of the plow package you are considering. It shouldn't be too heavy for your unit to handle or you will end up damaging your Pioneer. Other factors come into play such as suspension, tires, and lift kits. It is wise to review this before making the purchase.
Desired use.
Do you plan to plow every sidewalk in town or have a long driveway with continued snow? Then it is highly recommended you invest in a top plow with hydraulic tilt. But, if you are the small ranch owner that only gets 3-5 inches a year it would be wise just to pick up a basic plow that will get the job done all the same.
YOUR WINCH and strap.
This is often overlooked
when buying a snow plow. Your winch must be working and dependable. A cheap winch will leave you frustrated after constant use. It is high probability your strap will break at least once a season. To help prevent this consider upgrading to a lift strap and smooth fairlead to better handle the load. Adding a pulley system will also extend the life of your cable or rope lift.
And finally, Your Budget.
While we all want the best sometimes it is just not worth it when a basic snow plow will push the snow just as well as the top brand. Consider if you can turn a profit somehow by plowing your neighbor's driveway or striking a deal with the local retailer to plow there parking lot. It will be fun and you can recoup some of the cost.
Here are several SNOW PLOW SOLUTIONS for your Honda Pioneer Side by Side!
Img 20170220 171327 jpg
BOSS Snowplows.
--> BOSS Snowplow | UTV ATV Equipment
Boss offers one of the best snow plow line-ups on the market. They offer a wide range of show remove equipment and 5 different plow options for your Honda Pioneer.
- Pioneer 500 recommend the ATV Snowplows line
- Pioneer 700 recommend the Mid-Size Snowplow line
- Pioneer 1000 recommend the Full-Size Snowplow line
For pricing contact BOSS here --> BOSS Snowplow | Quote-Request
0002543 900
WARN ProVantage Plow Systems
... is offered in 54", 60" and 72"widths.
- Pioneer 500 recommend the Warn Plow Mount 93730, with the ProVantage Push Tube 92100, and the WARN 78954 ProVantage 54" Straight Plow Blade
- Pioneer 700 recommend the Warn Plow Mount 93954, with this ProVantage Push Tube 79850, and the Warn ProVantage 66" Plow 90695
- Pioneer 1000 recommend the Warn Plow Mount 93820, with this ProVantage Push Tube 79850, and the Warn ProVantage 72" Plow 79958
KFI20POLY20BLADE
KFI Snow Plows.
KFI makes a range of snow plows for most any unit. You can view their full selection here --. Snow Plows - KFI ATV Winch, Mounts, and Accessories
- Pioneer 500 recommend the KFI 105615 mount, with KFI Push Tube 105635, and a KFI 60" straight blade 105060
- Pioneer 700 recommend the KFI 66" Pro-Poly Snow Plow & Mount Kit
- Pioneer 1000 recommend the KFI 72" Pro-Poly Snow Plow & Mount Kit
71WQ2BgMK0TL SL1500
SUPER ATV Snow Plow kits
- Pioneer 500 recommend the 60" SuperATV Pro Heavy Duty Snow Plow
- Pioneer 700 recommend the 72" SuperATV Pro Heavy Duty Snow Plow
- Pioneer 1000 recommend the 72" SuperATV Pro Heavy Duty Snow Plow
076b9bfa baf3 4c17 891a 862ab3d05e7f jpeg
DENALI UTV Snow Plow Kits
- Pioneer 500 recommend the 60-inch DENALI UTV Snow Plow Kit
- Pioneer 700 recommend the 66-inch DENALI UTV Snow Plow Kit
- Pioneer 1000 recommend the 72-inch DENALI UTV Snow Plow Kit
AEA6E151086E67807CF822CA14D02818app1 1519152785332 L1800
TUSK SubZero Snow Plows
- Pioneer 500 recommend the Tusk SubZero Snow Plow Kit, Winch Equipped UTV, 60
- Pioneer 700 recommend the Tusk SubZero Snow Plow Kit, Winch Equipped UTV, 72
* there is a 66 inch but fitting does not suggest it fits the 700??
- Pioneer 1000 recommend the Tusk SubZero Snow Plow Kit, Winch Equipped UTV, 72
Finally.
Do your research and choose what fits your needs the best. Most of all, get it ordered and installed before winter hits so you can have a blast plowing the entire neighborhood.
Leave a comment and tell us which brand you decided to go with. If you selected another brand, drop a link with a few details. We would love to add it in!
Happy Plowing!
Eslinger_18
Eslinger_18
Wake up and piss excellence!
42
102
Mt. Angel, OR
I just picked up a used 72" Denali blade for this winter. I've rigged up a block/pulley system to reduce wear on my winch line. It's a slick setup. I'm excited to put it to use!
Reactions: swsebek
E
elkguide
3,377
7,964
Vermont
Have used a 72" Moose plow for the last two winters and am very satisfied.
(especially since I switched to a synthetic cable!!!!!)
OnTheJob
OnTheJob
426
925
Bristol, NY
Anybody run the BOSS V-XT? What's the price range on that and what about all that weight on a stock set up? That price is more than 4x times most others.
41443142 10212720150937985 5478778067960725504 n
Reactions: p1k5James
Neohio
Neohio
Beast of the East
17,719
85,397
Painesville Ohio
The boss blade is a full hydraulic snow plow. Independent V blade. Definitely need a 2nd battery for that! Or a full size battery under the seat.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Those of you that use the Warn ProVantage setup... do you take the plow mount off during the summer? Leave it on? What does it look like with just the mount?
Badblubug
Badblubug
175
356
North woods
I purchased a kolpin switchblade, it is a universal and the plow is 60” and adjustable to 72” I keep it at 60”
It works fine but I really don’t like the mount, wish I had purchased the Honda set up, I say spend more and pass on this setup
Put my back window and doors back on this weekend, I’ll put the plow mount back on in early November
Skinelli
Alaska
I like the tusk snow plow kit. I have a 2019 pioneer 700 with a KFI winch mount. Do you know if this will work on this machine
T
thomasvandermars
17
Montana
WINTER IS COMING!!!
Blade Width.
Weight.
Desired use.
BOSS Snowplows.
KFI Snow Plows.
Finally.
Happy Plowing!
Anyone put tracks on and plow. I think I need about a 78" blade but can't find one.
A
ASAT
Eastern mn
Just ordered up the 72" warn ProVantage with the full limit switch kit for my 1000-5. Hoping its as nice As I expect it to be. Anybody have issues plowing at night with the stock headlights?
G
GEM1N1998
36
62
Lee's Summit
Anyone know the weight of the 72" Denali Pro? I've been going down the rabbit hole of plows. Here are my notes so far.
KFI Pro Poly 72". - 87 pounds
Western Impact UTV 72" - 261 pounds
The Western is an awesome plow with true hydraulics. I'm worried about the weight on the front of my P1k-5 LE.
I can't find the weight of the Denali pro.
G
GEM1N1998
36
62
Lee's Summit
Response from Denali.
Our Pro blade weighs 110lbs, push tube is 58lbs and push tube is 15lbs
So question. Would the Western be too heavy for the P1k? That seems like a lot if both teh denali and kfi come in around 100 pounds less.
z4abraha
z4abraha
7
31
I can’t help much for the 1000 but my P700 does a great job with the 72” Denali. The front does squat slightly while the plow is lifted but still plenty driveable. I’d be willing to guess the western might cause some rubbing up front especially if you aren’t running the stock wheels.
bh1332
27
35
Wyoming
I am curious about this too. I am trying to figure out which snow plow to purchase for my 1000-5. I've read the Warn Provantage has some weak points that have bent. Also curious about the question above regarding whether or not people take the Warn front mount plate off during summer riding season. Also, weight considerations of the Warn vs. KFI Pro Poly.
G
GEM1N1998
36
62
Lee's Summit
highly recommend this plow from these guys. I’ve had questions on a few things, emailed the owner on a Sunday night and received answers within 30 minutes. Customer service like no other from an American company.
Oh yeah, and the plow is pretty good too
