P1000 2018 Pioneer 1000-5 rear differential shows locked in turf mode
brettc
brettc
84
294
53
Little Rock, AR & Crawford, CO
IMG 4121
Well it was pretty obvious why mine wasn't working right either. I jacked the rear end up, made the adjustments and it worked like a champ. Thanks for all the great info.
Hunt4x4
6
14
Ohio
  1. Looking to buy
  2. 700-2
Do you make this adjustment while the machine is in park and 2wd or while it’s in neutral and turf mode?
“To me it reads turn the rear wheel and check the release of the rear diff lock.” Only happens in neutral and turf mode. Then it proceeds to explain the alignment.
I’ve watched several videos and they are adjusting while in park and 2nd.
If I’m reading the manual correctly you are adjusting the turf mode/ disengagement of rear diff. So it should be in neutral and turf mode when making these adjustments.
can someone clear this up?
P1K5Dave
P1K5Dave
2,329
8,685
Petoskey, MI
Follow this video. Get it set so it engages and disengages in 1/2 turn of the tire.
The method in the manual is insufficient.
TripleB
TripleB
20,629
180,404
Caryville, Tennessee
I was in park and 2wd when I adjusted mine. It's been 2 years since I've did it. It took me multiple times adjusting it to get it to work the way I wanted. Been good to go since.
Spoonbill
Spoonbill
227
273
East TN
This is an extremely poor design. With every throw of the gear into park or switching from 2WD to Turf the connection from the tensioner to the cable is repeatedly stressed. Honda made significant improvements on the 2022. Makes me wish I would have held off a couple of years??
Reactions: ChadD and ODAMO
Spoonbill
Spoonbill
227
273
East TN
Any idea if this is too difficult for a DIY?? I've done quite a bit of mechanic work over my life, but if this requires special tools, that is an entirely different story.
Reactions: ChadD
Fatsquatch
Fatsquatch
Approved Member
121,156
1,010,319
Hidden
I’ve not done one. Just looks to me like yours might have been over crimped or over tightened and broke. As clean as it looks I don’t think you did anything. I think you got fucked by the factory. 😢
My guess is it will be worth your time to DIY it but it is probably going to be a PITA to chase the cable. You could always call your stealership and talk to the service department though and find out what they would charge you. Show them the picture and ask if it would be a warranty repair. If so, get it in writing so you don’t get a surprise when you pick up the machine.
Ultimately I do think anyone that can change oil could do this repair…just expect to scrape some knuckles chasing that cable.
Reactions: ChadD and Scoop
Scoop
Scoop
5,399
21,259
  3. Talon R LV
Prolly just swear a few more times than @GovtMule installing electrical bits ... if that's even possible. :D
Reactions: Spoonbill
62,510
@Spoonbill
I've never heard of anyone breaking one of those before and I've seen a BUNCH of those shiftboxes completely full of mud/sand/water and they still seem to hold up. Yours looks immaculate, so I'd lean towards it just being a fluke. Looks like you just need #9 here and it shouldn't be too hard to replace since you can get to it all pretty easily with the bed up:
1720533174575
1720533195157
Remove it from the clips and pop off this plastic cover on the rear diff (#28). Should be no more difficult than changing the brake/shift cable on a bicycle:
1720536147044
Spoonbill
Spoonbill
227
273
East TN
@Spoonbill
Thanks to everyone who had contributed! This is why I subscribed to become a Lifetime Member.
