2018 Pioneer 700 deluxe issues
mikerog
6
15
Florida
Had my Pioneer 700 out this Saturday for ride and it suddenly engine started running erratic and then just died on me. All indicators on dash screen flashed as it died. It cranked right back up and I proceeded only to have it occur 2 more times. This has never happened. Engine overheating light did not come on. Machine is well maintained and serviced. Plugs new, oil ok. I waited 5 minutes, poured 16 ounce of water on engine then cranked it up and it ran fine again. I have read others have had a similar issue and have solved by replacing fuel injector wire harness and PCM. Any suggestions out there on what might have happened. I fear it is going to happen again since it now occurred and their must be some issue. Also, I cannot find anything on internet on steps to change coolant in the Pioneer 700. Hate paying a dealer to do something I feel I can do. Any detailed steps or video how to do this would be appreciated. I only have 1300 miles on machine. thanks
IMG 0049
115,818
my Pioneer 700
First off Welcome From Michigan.
You have 2 post now since Joining last December and no pics.
Rule #4 Pics Or It Didnt Happen!
we like pics And Visual Verification ;)
As for your problem, did you swamp it? Also check your grounds especially the one on the frame engine. I just had one that deteriorated and went bad on my P1. It was causing some erratic Idling and weird electrical that would shut it down. So check that.
also, If your over heating, wash the fuc out if that radiator, youll be surprised what you find. You have only 1,300 miles on that machine So u say cuz we have no pics yet for verification🤨🥳 you dont need to change the coolant at that milage unless you swamped it so leave it alone. But if you insist, use the search up top and be patient and read through. Its in there.
JenElio
JenElio
75,052
676,996
Loxahatchee, florida
welcome from south Fl
Like Remi said, check all your grounds and let us know. Post a pic or two when you get a chance 😉
What part of FL?
43,292
Read through this if you haven't...
mikerog
6
15
Florida
My Pioneer above continues to stop running randomly. Same situation as I described above. Any ideas on what might be causing this.
NTCPrezJB
NTCPrezJB
Retiring Member
112,828
975,779
Hidden
Finally found the problem with random shutdown of my Pioneer 700. It was a corroded and loose ground wire. Runs like new now.
Good deal 👍
Thanks for coming back and updating ✌️
Appreciate the update Fo’Sho!
Those damn grounds just seem to solve a lot of random issues. Stupid magic pixies!
