P700 2020 Pioneer 700-4 Deluxe dies expectantly while driving
hays4
5
6
Hannibal MO
The other evening I was driving some country roads and on three different occasions my machine died on me without any warning. No bucking, no surging, etc? Like it lost its electrical power. I didn't notice any warnings or error messages on the display. Each time I turned the key on and it started right up. Only one instance did I feel like it was lagging for power for just a second. I have put in plug into the accessory port on the wiring harness and have a 18" LED light and a soundbar hooked up to that. At the time it died, both of these were on. I noticed my voltage meter was reading around 13.4: could this be the culprit?
Reactions: Biteme
Russ989
Russ989
22,642
147,257
13.4 is still above 12 volts. When I’m running my whips, light bar and high beams on my 1000 my volt meter is around 13.8. I don’t think thats your problem. 14+/- when nothing is on and at idle. Check your ground connections.
Reactions: Biteme
hays4
5
6
Hannibal MO
Brand new unit: never been in water. Just passed 20 hours on it and about 130 miles.
Reactions: Biteme
Mudwing
Mudwing
36,959
306,672
The Mud holes
I would check both terminals on the battery and ground connections. While you’re under the seat near the battery, check the plug in connections to the PCM too. 😉 Post an update when you solve it. 😎
Cazadore
26
19
Az
My ‘17 is in the shop right now for the 2nd time in as many months for the same exact thing. Runs great until it doesn’t. Shuts off like someone turns the key off when shifting from 1st to 2nd or 9-10 mph. Which ever comes first. Starts right up each time. First time in the shop they couldn’t replicate it. Tech said a loose connection was found, cleaned and reset. Took it out today, after 20 miles or so, it started dying again. Again limped it home starting and dying all the way back. This will be the last time I trailer this pos. As soon as it’s out of the shop I will be trading it for a can am. I cannot afford to be stranded in the remote country I hunt in. Not only inconvenient but could be dangerous.
Reactions: Biteme
Slackjaw
Slackjaw
293
462
Durham NC
I wonder if this is a symptom of the fuel pump recall/upgrade. Sure sounds like it.
I'd have all the updates performed first.
Reactions: Biteme and TripleB
Cazadore
26
19
Az
I don’t think this applies to mine. Mines a ‘17 and when it dies it will fire right back up as soon as it stops rolling. It idles perfect and then dies again as you start rolling again.
Reactions: Biteme
hays4
5
6
Hannibal MO
So I believe I have found what my issue was: I was using a wiring harness that plugged into the test port. I removed this and bought a "Plug and Play" harness that attaches to the cigarette lighter harness. Since I did this, I haven't had any problems.
43,292
The diagnostic connector under the hood?
Reactions: wrhii
Randall2385
Kansas
My problem is a little different. I was driving down the road and all at once the machine started running rough and would only run 10 to 15 mph made it home and now acts like it is starting up against a lot of compression and won idle.
Cazadore
26
19
Az
Got the call from the dealership yesterday. They are sending the case to Honda for advice as they cannot find anything wrong. No codes are being thrown, unable to replicate etc, etc..
Reactions: Backwoods
Cazadore
26
19
Az
Dealer update. Still in the shop. Techs sent information to Honda for some advice. Honda eventually replied with a list of things that "could" be the cause. The techs settled on the PGM or PCM, not really sure. I don't know what that is. Still waiting for word on when the part will be received and installed.
Reactions: Mudwing
Cazadore
26
19
Az
Finally got it back from the shop after 5 1/2 weeks. Replaced the ECM and did the steering knuckle recall. Never could replicate the problem. We’ll see how it goes from here.
43,292
DI'd you find the problem? Mine is at the dealership now with the same issue.
2020 700-4 Deluxe
Read this and see if it matches your symptoms...
Reactions: Buggyman
