2021 Honda Talon 1000X-4 Live Wire
Jmaxx1502
Jmaxx1502
115
151
Cocoa beach
  1. Talon X4
What is the correct alignment specs for a 2021 Talon X4 LW? I’m installing new high clearance forward (1.5”) moving A-Arms and want to get it correct. Only has 6-miles on it and looks like the factory put in some toe out on it or it’s not right out the gate. I’m thinking 1degree camber and 1 degree toe out would be good at ride height?
8D1D8819 AC09 463C B8F7 525B3EA47A54
5,492
25,269
My service manual says toe in is 0, so point 'em straight ahead. Camber isn't mentioned.
PaulF
PaulF
1,462
4,815
My 2019 service manual says...
Camber
Front -.8 degrees (that is negative camber)
Rear 0 degrees
Toe Front and Rear 0 degrees.
I don't think anything has changed in 2021.
Reactions: TxDoc and CID
