P1000 2021 Pioneer 1000-5 LE - runs less than two minutes, then stalls - SOLVED!
StewB
StewB
730
3,393
This post is an answer trying to catch questions. And help.
I have a new 2021 Pioneer 1000-5 LE. It would run from 15 seconds to two minutes, then stall. Hard stop, sudden stall.
Felt like a fuel side problem. Changed the fuel and no luck.
Two trips to the shop (second time involved a lot of bird-dogging) and they found the solution.
The engine-side ground was loose. It's under the bed, beneath the plastic.
I've just put my first 100 miles on it, and it works great.
I wanted to post this just in case it happens to anyone else.
StewB
67,170
Here is some more info from a few years back.
Intermittent electrical problems
Lady01
Lady01
192
488
Midland Michigan
StewB
Nice, thanks for following up on this symptom and fix!
