2021 Talon Cranks but won't Start
212,781
gradesSorry, those are the numbers you add together to get a code. Short blinks are equal to 1 digit and long blinks are early to 10 digits.
Example:
5 long blinks
7 short blinks
Would give you code 57.
Hey Mr Honda Tech, I've been chasing a burnt oil smell for a while, no oil on the shop floor, motor that I can see or skid plate. Dad was riding with me last week and said it smelled like crank case ventilation oil. What's weird is it gets stinky on long down hill grades with no braking? With throttle applied no smell?
HondaTech
The only crankcase vent on the Pioneer is in the valve cover, vents directly to the airbox. Might check and see if it's come on either end. I've seen them left off and they don't make enough of a mess usually to show an oil leak.
212,781
Thanks!
ScottJ24
ScottJ24
82
227
Cresson, TX
Example:
5 long blinks
7 short blinks
Wyou a code 57.
Example:
5 long blinks
7 short blinks
ScottJ24
ScottJ24
82
227
Cresson, TX
Problem solved. I had installed a wiring kit to the subtrans harness to activate a backup light. I removed it and everything is back to normal. I tried to re install it and the same problem and no no pins were bent. I made sure to seat both ends all the way. At least it runs now.
DRZRon1
DRZRon1
1,456
4,442
PA
always more to the story……..That tidbit of info 😭 woulda saved a lot of drama and grief for those who get emotionally vested in getting ya back running -
generally it’s the last thing touched or modified that’s the problem - lol
906UP
906UP
15,062
143,173
da Yoop
Yup 🤦‍♂️
Reactions: scottkooch
GovtMule
GovtMule
22,170
189,243
Tennessee
Wordz of wizdem there!!!
