2022 1000-5 shutting off at 4500rpm
rpfeifer11
rpfeifer11
52
Mt.Pleasant PA
2022 1000-5 not running after washing it. I tried pretty much everything suggested on Facebook without luck but narrowed the issue down a little. Itll idle and ride as much as you want below 4500rpm but won’t run at all above 4500 rpm. Doesn’t matter if it’s in neutral or any gear. Does the same thing it just stalls and the check engine light comes on. I had a lot of responses about maybe taking water in while washing through the gas tank breather but the breather hose was dry when I took it off at the tank and it’s not breaking up at all when it’s idling. Seems like an electrical issue to me. I also checked the air filter and it was dry. Took the bigger electrical connections apart under the drivers seat and dried the ones that had a little bit of water in them but no changes. Figured I’d try once more before taking it to the dealer. Thank You
1F35BF51 3313 4F9F A9FD AAB3E583E3C0
115,818
2022 1000-5 not running after washing it. I tried pretty much everything suggested on FACETURD without luck but narrowed the issue down a little. Itll idle and ride as much as you want below 4500rpm but won’t run at all above 4500 rpm. Doesn’t matter if it’s in neutral or any gear. Does the same thing it just stalls and the check engine light comes on. I had a lot of responses about maybe taking water in while washing through the gas tank breather but the breather hose was dry when I took it off at the tank and it’s not breaking up at all when it’s idling. Seems like an electrical issue to me. I also checked the air filter and it was dry. Took the bigger electrical connections apart under the drivers seat and dried the ones that had a little bit of water in them but no changes. Figured I’d try once more before taking it to the dealer. Thank You
Fixed it for ya! ☝️ ;)
Welcome from the Putrid Swamp Run Michigan!
Nice rig! Go Army Green!
A few things before we get started, theres a search up at the top of the screen, always check your problem with multiple different words first cuz were know a thing or two cuz weve seen a thing or two! Lol
But we’ll help u a bit with this one….
You washed it! And the issue occurred You most likely have some moisture in some of your molex connectors and or in your CPU very common when folks wash them real good! You need to dry that puppy out REAL GOOD EVERY WHICH WAS OF SUNDAY before you can go any further! Also, check your air filter and make sure its not saturated. Do that, then come back and let us know! Dont leave us hanging!
RedorDead
84
475
53
USA
How long had it been since the wash? Hours; days? Point being how much time for drying.
Is it or can it be parked in a dry low humidity environment? It’s likely water in a connection somewhere.
Was a pressure washer involved? I ask because if water got in from a low pressure wash, I’d be wondering when it might recur just from driving in the wet. In which case identifying the specific culprit would matter to me.
rpfeifer11
rpfeifer11
52
Mt.Pleasant PA
I washed it on Saturday. Was perfectly fine before the wash. Washed it with a pressure washer. I tried to ride it immediately after the wash and that’s when I realized there was an issue. It’s been in a heated garage since then.
HBarlow
HBarlow
1,635
6,084
Daniels, WV
Yep, it sounds like you used a pressure washer and aimed the spray at the engine. It's an honest mistake but may be costly.
Modern engines like in our Honda 1000s are complex. They use electronic ignition and electronic fuel injection. Water and electronics don't mix well.
I'm just guessing here - your description suggests that something designed into the engine to kick in above 4500 rpm has been disable or damaged by water intrusion. Is there such a design feature? I have no idea. Just a guess.
Perhaps a Honda tech will see your post and offer informed advice.
I recommend you limit taking things apart to clean or dry components because it could cause more damage and you'll leave evidence which will make it more likely the dealer service department will determine you caused the problem. They won't be wrong.
If it were mine, I would trailer it to my dealer and tell them what happened. It would be unwise to lie to them.
Good luck.
john790
367
1,105
Clinton ohio 44216
Mine ran stupid everytime i washed it. You probley got water in the tank.If theres a small amount it will clear by its self.A bunch probley not.Change out your vent line and be more careful washing dont let the kids wash it.Watch where you spray.
Neohio
Neohio
Beast of the East
17,996
86,833
Painesville Ohio
Which codes are displayed on dash when engine dies? Can you upload a video to YouTube and share the link here? Nice 35-50 seconds video of the dash after it dies.
115,818
Exactly the point!
Mine is as well! Water in the nooks and cranies take a while to dissolve
would sugest when this is all done, get u some vent line extentions
rpfeifer11
rpfeifer11
52
Mt.Pleasant PA
I’ll try to get a video tomorrow. When it dies the check engine light comes on but I’m not sure how to read the codes. The check engine light goes back out when I restart it.
rpfeifer11
rpfeifer11
52
Mt.Pleasant PA
Good luck.
I have an appointment to drop it off at the dealer tomorrow so hopefully they can figure something out. I didn’t really think an off-road machine couldn’t be pressure washed but I guess I was wrong. I’ve had a few wolverines before this and currently have an rmax4 and all have had some serious washing done without issues. Guess I’ll just nickname this buggy “princess” 😂
RedorDead
84
475
53
USA
I use pressure washers at times. It’s all about how close you get to certain things. Could also be a defective seal on a connector and not your fault at all. Better to have it happen at home than get wet and die out on the trail.
rpfeifer11
rpfeifer11
52
Mt.Pleasant PA
Absolutely, I probably wouldn’t have cleaned it this good usually but it’s due for the 100 mile service and there’s nothing worse than working on it filthy. Hoping the dealer finds something stupid that I’m just missing. All the help is appreciated.
Neohio
Neohio
Beast of the East
17,996
86,833
Painesville Ohio
If the check engine light is flashing. Get that on video. It is long and short flashes. We can interpret it and let you know where to focus your attention.
rpfeifer11
rpfeifer11
52
Mt.Pleasant PA
Nice try! You fixed it in your reply not mine 😂 Will give u a B for effort. Libs are a little slow in general we get that 🥳 You'll catch on eventually!😘
NoHomo…
Now I understand why people keep saying fixed it for ya. This is my first time on a forum since exriders probably 15 years ago. Taking some time to catch on.
Jerryg
Jerryg
12,125
96,193
NEPA
JAH
