2022 Honda Talon 1000 4
Herkloader1
27
132
Montana
I just picked up my new Talon yesterday.
While at the dealership it kept dieing once it was put in gear.
They replaced the battery and all appeared to be good.
After a 12 hr round trip to pick it up.
We decided to take her out and get the break in done.
It ran great for the 20 miles we put on it. Even though I thought it started kinda hard.
Today I took it in to get the first service done on it.
All was good until they brought it out for me to load. Then Bam same issue as at the dealer yesterday.
Battery was dead.
They hit it with a quick charger and it started and ran for 15ft while the charger was still hooked up to it before it died again.
Ended up taking it to the local Honda dealer and they think it might be a bad Altenator.
Which was my thought that something on the charging side was bad.
Anyone else have this type of issue?
I have a 1000-5 2022 pioneer and love it. I put 1200 miles on it this winter innthe Dessert and mountains in southern az with now issues.
Kinda hoping I did not get a lemon with my Talon.
115,818
Battery was dead.
Well buddy, looks like you got it to a good dealer to check it out. Id check the grounds myself. There known to come loose and loose from the factory. Yes u could have a bad alternator but its unlikely being new. Some service guys (im a service guy) tend to jump into the difficult BIG things first. And neglect to check off the easy stuff first which in most cases is the issue. Hope u get it resolved soon.
There helped you out lol.
Help us out and get some pics up of your two machines. All you have is a bald tire pic. Come on man! 🤣 POIDH!
HondaTech
So simple to check charging output on these. At idle the battery voltage should climb to around 14 volts. Even with a s*** battery.
I'd check the simple things first if the unit doesn't seem to be charging.
Regulator/Rectifiers have been unplugged upon arrival before, but its rare.
The stator is also easy to test. Output from each of the 3 pairs, then continuity to ground and each other.
Any dealer worth a f*** would've never let a brand new unit leave, let alone twice with these symptoms.
115,818
Yup like i tell my new Generator techs… work smarter not harder!
208,730
Dear Lord thank you for the many blessing you have bestowed on us today. Lord please Bless each and please forgive each one of us heathens, we humbly pray. Good night NTC!
5,492
25,270
Battery was dead.
One of those digital voltmeters that plug into the cig plug will tell your voltage.
For example -
HondaTech
115,818
I like to know source voltage, or volatge at the battery. Those plug in things can be off by a volt, in either direction.
There ok for reference but never rely on anything not directly reading voltage off the battery.
Yes I agree 100% good for reference only. I have customers that do stuff like that with there generator and think its the bible till i show them the actual in my diagnostics to true source.
Im sure @CID wasnt really going that direction.
5,492
25,270
Thanks, Remi. Yeah, the guy needs a place to start, if the plug-in shows ~14 volts, it's not the stator.
Herkloader1
27
132
Montana
They said it is a Stator.
I trust them about as far as I can throw them though after my previous experiences there.
So.e said I need to add some pics, so here ya go.
20230428 130236
60,992
We have had good luck with our 2022 Pioneer.
It had a crap alignment out of the box, but otherwise a great machine.
We put 1200 miles out in the desert and mountains on the Mexico border in AZ this winter.View attachment 387016
Pooch looks tired from using that shovel, give him some help!
Herkloader1
27
132
Montana
Dealer called today. They actually looked it over despite them thinking they knew what it was.
They had rush ordered a Stator and Voltage regulator.
Today while they where looking it over they saw the ground plug for the Voltage Regulator was just dangling and had never been plugged in at the factory.
So I will get my Talon back tomorrow and will be able to take her for a few rides before I head North to Montana for the Summer with her.
Thanks for all the inputs!
HondaTech
#calledthats***
Edit: You know what's even more f***ed up? In order for them to have "tested" the stator, they would've had to access the Regulator. Since the stator plug is directly connected to the Regulator. Definitely a bunch of parts hangers.
DRZRon1
DRZRon1
1,248
3,981
PA
#calledthats***
bet u hate being right
my hunch is also paid for dealer prep
hunch is dealer also claiming warranty $
interesting
