2022 pioneer 1000-5 cabin heat update
NorthernJoe
NorthernJoe
369
1,408
Northern Ontario
My next “project” is to try to build a defector of sorts to direct the hot air from the fan and radiator down and to the sides, more or less to seal the under hood and dash areas from direct contact from the hot fan and radiator air. Going to need to remove the hood, grill and front fender to do that. Right now all that hot air hits the dash and under the hood. This has a side effect of making the Intake Air Temps very high. Maybe kill two birds with one stone?
I'd love to see that when you are done. take lots of pictures, What adds to my hot cab is the glass windshield,full hard doors and hard mid-panel
IMG 7631
mlynch001
mlynch001
193
879
Dardanelle, AR
That much enclosure will make it almost unbearable. I will post here if and when I make that modification. I see why you want to get some help with the heat.
Reactions: toddvdh
NorthernJoe
NorthernJoe
369
1,408
Northern Ontario
In the summer it can get hot. It will be nice when the snow flies. I may remove the doors next spring and run the factory 1/2 doors
for the summer
Here is the other extreme
.TempImage7fnH8e
sorry I don't know why the picture flipped
N
Nvrgiveup
We did rig up a redneck windshield vent though. Worked awesome! We will be replacing the bottles with pool noodle cut outs. Our shielding lessened the problem but it was still there. It was about 90 degrees out and we stopped a couple times to cool our behinds. We will be mounting a radiator fan below to blow the heat out. I can't believe anyone would say it may or may not be an issue. By the design it is an issue. You sit atop a tranny with an engine directly behind you. It baffles me an underbelly fan is not standard equipment.
We both love the machine and do not regret our purchase at all. Just something to fix...on an all said and done $25k machine jeese.
That’s some redneck 💩 right there. And I LOVE IT!!!
W
willieronk
30
123
MT
At the risk of triggering someone with a 2022 model, all I can say is if you think your 2022 model is hot, you should thank Sweet Baby Jesus you did not buy a 2016 model. Our 2016 was a salvage rig and barely ran when we first bought it, but even on short trips, it would cook you alive. it was one hot and miserable SOB. That being said, I have a much improved 2016 to which I have added the Heat shield attached under the seat bottom, a bilge fan, extensive extra insulation on all the other panels surrounding the engine, Insulation materials added to BOTH SIDES of the panel between the upper and lower seat cushions, seals on the shifters, seals around the steering column, 3D Printed, roll bar mounted air deflectors, TMUG Windshield extenders, Additional seals on the seat belt anchors AND I have added the 2022 model under seat panels and seat belt seal panels.
My machine has a temp sensor and PID controller to operate the bilge fan. This allows me to monitor the actual under seat temps to determine if my modifications have helped. I can tell you this, the 2016 with no modifications has a bottom of the seat temperature of in excess of 180 degrees on a very hot day. I my current configuration, the under seat temps run from 110-120 on a very hot (100 degree) day here in Arkansas. Our typical riding day is 85-95 degrees and 70-80% Humidity, with many days being much hotter; so heat is a real problem here. Adding the 2022 under seat panels to my 2016 made a HUGE difference along with even more extra insulation, sealing the seat belt anchors. I have spent a lot of time and a little bit of extra $$$ to make my 2016 much better than stock, and from the sound of it, even better than the 2022. The 2022 does have a lot of good changes, but there are still improvements to be made.
Thanks to all for the good ideas and commiseration...modifications pending.
Reactions: mlynch001
