Ya built this plate. Just welded the two lower mounts that slide around the factory receiver holes (could use hitch pin or bolt) and welded upper angle iron on that bolts to suspension mounts. Did drill all way through them added a spacer in between. Easy unbolt for full access to anything...
hondasxs.com
