2023 Pioneer 1000-3 Cab Heating Issue
STLG67
10
9
Southeast Texas
We brought this side by side home on May 6, made the first ride on May 12. Once the ride started, my wife noticed alot of heat on the back of the seat in the middle moving towards her side (passenger). I called the dealership we purchased from the next day and made arrangements to bring it in at another dealership that was closer. Also made a case with Honda Corporate and had a case number generated. So far after the bike being at the dealership for two days, Honda responded and said there's nothing wrong and that we need to wear the appropriate clothing while riding the side by side. Well we had long pants and a short sleeve shirt on, but the problem goes back to 2016-2019 from what I've researched since this issue started. There was a recall done and heat shield installed on the 3 seater and 4 seater units. I guess they don't want to admit that they haven't fixed the problem.
If anyone has any ideas how to move forward with this I would greatly appreciate your assistance. Thanks
Scoop
Scoop
5,192
20,515
  3. Talon R LV
These aren't Jeeps. They are SXS with motors sitting directly under your arses.
Seriously use the SEARCH function on the forums - there are elevendy billion posts about cabin heat and what things you can do to help reduce it (very little, actually).
Welcome to the forums!
Better post some pics of your new ride or the local sheriff will be around soon to write you up!
115,818
Welcome from commie run Michigan!
Looks like my deputies up top have covered this for you. The only thing they haven't mentioned is pics of your rig in question. Its Rule #4 when u join/first post so...
Pics Or It Didn't Happen!
115,818
If none of that helps, Polaris North star edition or a Jeep would be your best bet.
Id stay stay away from the jeep, he'd complain about the electrical nightmare they are. And Negatory on the Poo Poo as well! He'd open a case about the multiple fires he will have🔥 :oops: 🥳
I think he needs a Kubota 🤣
Scoop
Scoop
5,192
20,515
  3. Talon R LV
I carry a fire extinguisher to put out the fires in the Poo Poo's!
182,485
Someone didn't do their homework. This has been a known issue with all the Honda's and other brands for yrs. Honda corporate determined that you're not experiencing anything excessive and it's totally normal. They've done some refinements to address the issue over the yrs but none of them have eliminated it. And as stated above, nothing will totally eliminate it. Like Triple B said, throw in a bilge fan and a shield and you'll be good to go...in the front seat anyway.
HondaTech
Speaking of burning Poo
Screenshot 20230519 140045 Chrome
Mopower58
Mopower58
Unburdened by what has been!
81,406
718,593
Crystal Springs,Ms.
Welcome from Mississippi. I have a 2016 and installed a rubber shield under the seat from @trigger . I also have a half windshield and an Alien shade for a roof. The only alternative might be a Pioneer -6 as the engine is further back. I see you're from South Texas so the heat should be normal. I am in the Southern half of Mississippi so we're used to the heat.
#NTC
ODAMO
ODAMO
1,287
3,464
Ohio
#NTC
I would think the heat from a Pioneer would feel like AC to a South Texan.
DRZRon1
DRZRon1
1,248
3,981
PA
need pics and update on your Honda Corporate opened case for excessive heat...
chucksmith0706
295
1,102
Louisiana
I put a thin piece of bubble insulation under my seat and up the back a little. Then I went ahead and installed a small fan to blow the heat towards the rear. Made all the difference in the world.
Reactions: Vikes79
