P500 27x9 tires all around on stock rims
F
Flyin51
Mississippi
Hey guys. I’m about to buy a P5 real soon, and am trying to decide on tires so i can set it up right away. Can a guy run 27x9 tires all around on the factory rims? I wanna go taller, but not necessarily wider than i have to. Definitely trying to keep weight down. Apologize for my lack of knowledge as I’ve been outta the ATVs/utv game for awhile. All replies are greatly appreciated!!
Reactions: 500oneer
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I do not have an answer for you. I am still running stock wheels/tires on my new P5. But I'm positive somebody on here will chime in.
dls1966
dls1966
192
569
Kawkawlin Michigan
The stock rims are 7.5 in. on the rear and 6 in.wide on the front so the 9inches wide will work and alot of people on this site are running 27 inch tires with no problems
I was looking to put larger tires on mine and wanted 27 inch but went with 25s because the door to my shop was too low
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
Thanks for the info. I may go with 25’s for the same reason. You got a pic with the 25’s?
dls1966
dls1966
192
569
Kawkawlin Michigan
20181013 203256
20181013 203217
20181013 203156
I
Igor
North Carolina
Hello. I have purchased P5 few months back and am trying to decide on tires so i can get better ground clearance. Considering 27x9-12 front and 27x11-12 rear STI Black Diamonds XTR Radial Tires.. Any negative experience with rubbing or would 26" run better? Also do you advice to keep factory rims or buy new 12" wheels? All replies are greatly appreciated!
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
[QUOTE="dls1966,[/QUOTE] Great looking machine! What brand tires are those?
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
27s with 5+2 offset rims, No problems. 9” wide front, 11 rear, if doing it again would do 9 on all four.
DaddyDubbs
DaddyDubbs
14,942
141,135
Also take into consideration tire manufacturer as not all OD's are the same or true to size.
I'm running Blackwater Evo's 26x9-12 on all four corners on 5+2 offset rims with no problems, and like the fact I can rotate tires.
I chose this combination because of vertical clearance in my enclosed trailer. In reality, I probably could go 27's as Blackwaters run slightly undersize, also air pressure will affect tire diameter.
Reactions: SouthwestORV
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
This is exactly what I'm considering at the moment, 26x9-12 tires on all four corners. 1) DaddyDubbs, will you please put up a few pics from different angles? 2) Also, does the 5+2 offset push the tires 2" to the outside, provided a 2" offset per tire?
Reactions: Rogerpierce
DaddyDubbs
DaddyDubbs
14,942
141,135
OEM still mounted with Evo's in front
Evo 01
Another comparison of OEM to EVO's
Evo 02
Here are a few different angles of the Evo's mounted
Evo 03 Evo 04 Evo 05 Evo 06 Evo 07 Evo 08 Evo 09
Regarding overall width increase with a 5+2 rim, you are only going to see about a 1" greater width overall as the stock rims are 4.5+1.5 - Here is a great article from our founder @Hondasxs - Pioneer 500 - Factory Wheels and Tires! and post 7 gives the specs I just referenced.
So far I feel the 5+2 offset has given adequate stability and I think I can still squeeze through the 48" trail posts, although I haven't tried yet.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
View attachment 93034 View attachment 93035 View attachment 93036 View attachment 93037 View attachment 93038 View attachment 93039 View attachment 93040
Thank you! Exactly what I was hoping for. That looks so nice.
Reactions: DaddyDubbs
Chadwick1968
34
37
Angola la
I have 9 on front and 11 on rear. Perfect for
