P1000 28 inch tires on 12 inch Beadlock
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yeah common get those new shoes on hurry it up.
You got um mounted yet??? Need pics! Let’s go pokie
Getting there 30304bc41a2ab7b2ea7f02180a691a59
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Have you measured them yet?
At 10psi they are 27.25inches to top of tire. At 20psi they are 27.75 inches to top of tire.
My LT tires at 8psi were 28 inches to top of tire
The berserkers are a 28x10x12 tire on a 7inch wide rim. I think that makes them round out a bit on the top of the tire but the contact patch appears to be pretty flat.
Really??
Reactions: BWAF
BigOL3
BigOL3
2,994
8,918
I have not checked my lately, but will try to do so in the next couple of day. When I first mounted them, I inflated to max pressure for a day, before lowering the psi. IIRC max was over 28.5".
Reactions: Tigermark and BWAF
BigOL3
BigOL3
2,994
8,918
I have not checked the tires out since installing them several months ago. Today they all measured 8psi, the rears are 27.5" and the fronts are 27.75", measured using a 2' level to verify legit height.
Reactions: JTW and TripleB
