BOX1 - TEST
P1000 28 or 30 Terrabites
Fravel
Fravel
Monroe, IN
All I’m sorry to ask another will it fit question but I have searched many threads and cannot find the answer. I have a 2021 Deluxe with stock 14” wheels and stock suspension. I plan on ordering terrabites this week to replace the crappy Armstrong’s that came on it. I understand 28x10x14 terrabites will work with or possibly without spacers BUT, can I run 30s with RB3 spacers? Wide track or super wide track? I appreciate your help.
Reactions: Lady01
test - test -test
Robobrainiac
Robobrainiac
2,457
8,553
30s will not fit without control arms that move the front axle forward. The rear does not require any modification for 30s. In my own opinion you are better off with the controls arms because it also gives an arch to them that gives you ground clearance. I run 28" SuperATV Intimidators with the high lifter control arms and I have slight rub at full turn under compression with 5+2 wheels and no spacers.
Spacers will not allow you to run larger tires. The reason larger tires cannot fit is because the axles are too close to the machine.
test - test -test
105,290
What ^^^^^^^^^ said mostly lol
If u run 30’s “this is for the rear” without arms or at least some aftermarket shocks with preload you will hit the the upper wheel wall in terrain.
If u get 28’s, id recommend the standard most common spacer set @RB3offroad offers to help with you not rubbing when turning the wheel all the way to one side or the other. Also recommend them with 30’s
And aftermarket arms
test - test -test test - test -test test - test -test
Sjc3081
Sjc3081
263
442
Wappinger NY
O would recommend get the 28/10/14 Terrabites or Kanati Mongrels. Both will fit without spacers,lift or forward A-arms. Try them and you can order spacers later of you want.
Reactions: Fravel and toddvdh
test - test -test
xltman
xltman
188
369
US
Has anyone tried the 29" Terrabites? They make them in the staggered setup if you want to stay stockish but oversized.
Sent from my SM-G973U using Tapatalk
test - test -test
grabbe123
grabbe123
155
Paris, IL
I run the 29's, 29-11-14's all around. I put high lifter 1.5" wheel spacers on the back to equal them out with the front. Put high lifter control arms on the front and back because they rubbed the front fender under compression. My shocks are stock, so my answer is go with the 28's unless you're going to do control arms!
20201011 180644
test - test -test
BOX2
box3 - TEST
