28x10x14 front and rear set up
E
EvanRay28
Tn
Will 28x10x14 tires clear stock and for rims what size and offset I can get a spacer for the rear to make it even if needed
HBarlow
HBarlow
1,622
6,034
Daniels, WV
28" x 10" x 14" tires mounted on Honda 14" wheels with 1" spacers at the rear is a common improvement on many Pioneer 1000s including mine. The tires clear without interference.
I don't have a spare so can't answer that question.
PaulF
PaulF
1,462
4,814
You are in the Talon section and it looks like you have a pioneer. You may try the pioneer section for more feedback.
E
EvanRay28
Tn
Mine has 14 deluxe wheels would those work my front now is a 27x9
Reactions: HBarlow
HBarlow
HBarlow
1,622
6,034
Daniels, WV
Yes.
The 28 x 10 x 14 is an inch taller, an inch wider than the fronts, fill the fender opening a little better, and have no contact issues with the body. use 1" spacers on the rear wheels to keep the tread width correct.
My buggy began life as a base model with 27 x 9 x 12 on front and 27 x 11 x 12 on the rear. I bought and installed a set of LE take-off wheels and oem tires with zero miles and then replaced the tires with Tensor Regulator 28 x 10 x 14s.
The tires were recommended to me by other members.
208,726
Yes.
Good tires!
Reactions: HBarlow
208,726
Might have been you who recommended them?
I didn't recommend Tensors, not they aren't an excellent tire, I've just had great luck with the ITP's
HBarlow
HBarlow
1,622
6,034
Daniels, WV
Many of the Chicomm, Korean, or whatever tires we buy for our Talons and Pioneers provide excellent service. The tires are probably all copies of the design and read pattern of good American brands and the tires don't carry more than 500 .bs. of weight/
K
KenThompson
280
621
Mulino
I would run the same wheels front and rear. NO SPACERS! Leave it a little wider up front. It will corner better. If you don’t believe me, ask any front end alignment guy that knows geometry
PaulF
PaulF
1,462
4,814
And it will tip easier and crawl worse and lean easier, etc.
The only thing a narrow rear end is good for is going fast and turning, it is detrimental for everything else.
Reactions: Backwoods
K
KenThompson
280
621
Mulino
Talk to any alignment pro that knows vehicle geometry. To each his own beliefs.
