P1000 2nd battery ground
helimech
helimech
110
190
I am adding a second battery mainly to run the winch from, my question is where is everyone connecting the second battery ground.
My feeling is it should have its own 6awg wire to ground , but not sure where the factory grounds are
Reactions: JenElio and Russ989
Russ989
Russ989
22,642
147,257
There’s a factory ground taped up and and zip tied above the factory battery.
helimech
helimech
110
190
I connected that to the winch relay, i guess i can connect the second battery to that also, thanks
Reactions: Russ989
P1000_DLux
P1000_DLux
Its Only an Opinion Relax
Belfair, WA
Whats your second battery? Brand? (Amazon link?)
Reactions: helimech
Russ989
Russ989
22,642
147,257
Reactions: helimech
helimech
helimech
110
190
I have not decided in battery brands yet, will be the next addition to the machine though
Reactions: Russ989
helimech
helimech
110
190
Just starting to wire everything to the factory battery until i order the isolator and second battery,
One thing i do have coming is a 250amp breaker for the winch power, it saved me on my last machine when the switch decided to stick on 'IN' , it actually bent in the bracket on the fairlead before the breaker tripped
15848837447562504425402237757490
