I recently added a second battery and a True isolator.
The isolator seems to be working correctly, and I am in the process of moving everything to the second battery.
The only thing currently on the second battery currently is a set of LED cubes, the primary battery has cooling fans and a winch on it.
The other night on the trails I noticed my volt meter was reading 13.7 on the primary battery with the cooling fans on, and up to 14.1 when the fans are off. The secondary battery however will not read about 12.5 even with all the accessories off and a constant 11.9 with them all on.
I didn’t know if this was normal or should I start searching for the issue. Could it be how I have the isolator wired in? I used the winch relay for my Common ground, it was the closest thing to the negative terminal. Or could my accessory battery be to small?
