P1000 30” tires
TripleB
TripleB
15,262
136,307
Caryville, Tennessee
Some guys claim there is some 29s that will fit but they have to be really short. Some 28s will rub when you ride hard and compress the suspension. My 28 inch evos would rub the inner fender at full compression. Buy 28s or do the foward arched arms on the front and run 30s.
obas
obas
11
31
Pell City, AL
I was about to post the original question, but hoping to get a little more detail from this thread before purchasing.
Can you run true 30” tires (System 3 xtr370) with 5+2 wheels on a Pioneer 1000 LE with SuperATV arched A arms? SuperATV's site states max 28" while HighLifter arms show max 30".
60,384
Yep
As long as you have the LE bumper (the tire will hit the bumper under compression on the standard Deluxe bumper). You may still rub on the edge of the plastic under the headlight as well under full compression. Pretty sure you'll get some rubbing in the rear without the arms on 30's.
30" Roxzillas with SATV forward/rear arms. I cut my front bumper and trimmed under the headlights once I figured out that's what was rubbing. No lift just the Fox QS3's with some preload added.
1613147443874
You can see where I cut the bumper shorter here (the LE bumper turns up right there)
1613147729183
tdhanses
tdhanses
1,044
3,553
Kansas
I don’t have a lift on mine but I do have forward arching front a-arms and Fox shocks, so on the LE you should be ok with just the front a-arms. Set your preload on Your shocks to get your extra height if needed. FYI I also have rear a-arms.
Now I also upgraded the springs on my Fox shocks so a stiff preload wasn’t an issue.
This is with factory Fox spring, no preload set.
23925F6B 2C29 4364 A25D 14F55EBAEA2B
This is with the new springs and preload set.
C0BF0C11 6E06 4997 BEEA 2162B9088C25
T
TMooney
View attachment 254798What is the manufacture of the wheel that good lookin ride an are they beadlocks
FoggyMtnBreakdown
FoggyMtnBreakdown
LaGrange, Georgia
View attachment 254798What springs did you go with? Worth it? How’s the ride quality?
FoggyMtnBreakdown
FoggyMtnBreakdown
LaGrange, Georgia
I went with cheap ones from summit, pick your flavor and yes I think it was worth it.
Ride quality is great.
Mind sharing the Length and spring lb that you went with? Did you purchase based on the weight of passengers and extra gear?... I have to load my pioneer down with weight to get it to ride comfortably on the trails..granted I do have my preload cranked for extra ride height.
tdhanses
tdhanses
1,044
3,553
Kansas
Front - 2.5” spring 14” 250lb
Rear - 3” spring 14” 300lbs
I went based on what many other here did and said gave the best overall ride, I think the progressive springs aren’t the best but I also changed mine out immediately so really don’t know what the ride was like with them.
