30" tires on stock talon 1000x 4
chambercr
Costa Rica
Is there a 30x11x15 rear and 30x9x15 front tire set? i want to keep the stock wheel but put a little bit bigger tires...
5,756
26,439
Many of us run all 4 the same size, whether stock wheels or aftermarket. Mine is in the shop right now getting a set of 30x10x15 tires and HD9 wheels. I went with 6+1 fronts and 4+3 rears which are reported to add an inch to each side, so 2" wider (duh).
chambercr
Costa Rica
Thank you! Could the 30x10x15 tires be mounted on the stock wheels even with the width difference between the front and rear wheels?
5,756
26,439
Yes, happens all the time. I think @Lil_Steve mounted 32's on stock wheels for a short time. I'm 'not happy' about downsizing the rears but many of the 30" aftermarket tires are 30x10. It just seems to be the way it is.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
I waited until I got the STI HD9's to mount my 32's on the Talon. I've seen at least one or two people mention that they mounted either 30's or 32's on stock wheels without issue.
Reactions: ScottyP123 and CID
