32” tires on 2021 talon 1000X-4 Live Wire.
Jmaxx1502
Jmaxx1502
115
151
Cocoa beach
  1. Talon X4
Hey guys another question from the rookie. My talon is brand with (6) miles on it. Do I need to re-program anything for the bigger tires? Worried about shift points, speedometer, etc. Also what can I do to get the power back to near stock levels with the added size and weight?thx
A56E68AD 28CB 4052 810F 65A48F56E16D
PaulF
PaulF
1,462
4,815
32's generally rub on the X model. It will change the shift points and may not shift into 6th (depending on the true tire diameter and weight of the tires). You will not "need" to reprogram the ECU shift points but it is recommended. Try without reprogramming and see how it goes.
Only way to calibrate the speedo is with a SpeedoDRD (or similar device)...
There is nothing you can do with a programmer to regain the power loss. At sea level, you "might" gain 4 hp and above 3000 feet there is nothing to gain so don't waste your money unless you are getting one to fix the shift points. You will need to do something mechanical to make up for the tire size difference such as IGR, Engine work, Turbo, etc to get any noticeable power gains on the Talon.
