P1000m5 5 Pin Rocker Switch
TxDoc
TxDoc
1,705
5,935
TEXAS 🇨🇱
photos.app.goo.gl
With a 5 pin rocker switch... With you have one LED on with keyed on power... And another LED on with the activation of the switch?
Thanks
Reactions: ProudDadOf5
Russ989
Russ989
22,608
146,956
64,640
So.
true Carling switches are better. (Ex. OTRATTW)
They are directly wired with resistors, wires and such (no circuit board) They are not affected as much by the elements like moisture.
Amazon specials. (standard switches) have a circuit board inside. Any moisture will cause them to fail.
People have had luck with the amazon specials. Others have not.
Haven't really heard any stories about OTRATTW switch failing.
TxDoc
TxDoc
1,705
5,935
TEXAS 🇨🇱
photos.app.goo.gl
I guess you have to buy direct. I'll call them tomorrow.
Thanks again for the info and help.
Reactions: Isaiah
TxDoc
TxDoc
1,705
5,935
TEXAS 🇨🇱
photos.app.goo.gl
I called otrattw the OTR switch guys.
I will order on Monday.
Two choices. Each switch has a logo like Light Bar and a symbol and an LED.
1-when the key is on you can have the LED come on and when energized, the symbol/logo lights up.
Or
2- you can turn on the key and the symbol/logo comes on and when energized the LED comes on.
He said he believes most sxs owners preferred the first.
But, I think I'd rather see what the switch is controlling lit up and the other LED to come on letting me know the accessory should be working.
Reactions: K9Paco
