Anybody running 6 + 1 Wheels and 32" tires? I am considering this setup (opposed to 5+2) in order to try and keep the overall width closer to stock and also to avoid rubbing the fender liner. This would be with 32x10r15 tires.
Less offset put that edge closer to the wheel well liner typically on the drivers side more than the passengers because of how Honda molds the floor tray left of the brake pedal, if it runs typically it is turning left with suspension compressed . What clears in the shop doesn't correlate that it clears in motion.I was hoping that a 6+1 would keep the scrub radius as close to 0 or factory as possible. i'm not sure where exactly these 32s are rubbing for people but I assume it is the outside edge of the tire tread, of the inside tire when at full lock, against the fender liner. Wouldn't having less offset help this issue?
Oh man, drawing with my finger on this lap top using MS paint a'int the best, but maybe it is good enough for this LOL. The black would be more offset, the red would be less offset. shouldn't that help with the rubbing, not make it worse? Maybe I'm thinking about it completely wrong?View attachment 204488
15" tires on 14" rims, that must be one hell of a leakSo I ended up going with Raceline Podium beadlock 14x7 6+1(+38) wheels and Sedona Rock-a-billy tires in a 32x10r15.
