P700m4 700 Rock Sliders
jjau06
jjau06
165
358
Finally got my 700-4 somewhat cleaned up from the abuse at the RRB Takeover and noticed I beat the factory rock guards, slides, tubing or whatever the correct term is up pretty nicely. Most of this was from going down Widow Maker. Any body got any good suggestions for somewhat straightening back out and some aftermarket guards to prevent this in the future? The tubing is dinged pretty good but my main concern is the tubing is bent out of alignment up approximately 1/4” to 3/8” on both sides. The passenger door now runs slightly on the bottom of the door jamb. Any thoughts?
Reactions: BWAF
Tramguage1
Tramguage1
Texan
7,496
30,714
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Pics please, if it the end of the tubing behind the B puller you can use a high lift jack to push it down. Put the base one the running board or tube, and hook the jack under the B puller crossbar atheon the shoulder belt connection point.
jjau06
jjau06
165
358
Will do, will try to get some tonight after work. . Thanks!
